Author Topic: Two odd items from work...  (Read 2869 times)
« on: January 20, 2022, 09:34:55 PM »
  Came across these while cleaning and sorting suff in the shop.  The first item is about 7 inches long.  The tines, if that's what they are, rotate; except the two inner tines can only move 90 degrees as shown in the last photo with one at the upper limit and one at lower limit.  The bar has a flat strip on one side only which doesn't seem to have a purpose.
The bottom photo is larger tool, over a foot long, which appears to mount on a 1" (approx) pipe.  The pipe is cut off and the stub inside resembles electrical conduit.
Offline international3414
Re: Two odd items from work...
« Reply #1 on: January 21, 2022, 03:30:41 AM »
last is phone co. lineman tool for wire probably bell system
« Reply #2 on: January 21, 2022, 04:48:11 AM »
Thanks!
« Reply #3 on: January 21, 2022, 08:15:22 AM »
The first item is most likely a anti-kickback device for some type of power saw.
« Reply #4 on: January 21, 2022, 10:56:56 AM »
I agree with international34114. Also called a Cope Hook.
« Reply #5 on: January 21, 2022, 08:26:50 PM »
Thanks.  I'll take a look at the saw in the shop (I haven't used it yet).  I'll see if that piece fits on there.
( Edit 1/22)  And yes the saw in the shop is a radial arm saw.
« Last Edit: January 22, 2022, 06:36:13 PM by amecks »
« Reply #6 on: January 22, 2022, 02:31:04 PM »
As Lewill2 stated, for a power saw, most likely on a Radial Arm Saw.
« Reply #7 on: January 22, 2022, 05:39:41 PM »
+1; you beat me to it.
