Author Topic: Stanley transitional plane with steel bottom  (Read 5785 times)
« on: April 10, 2021, 05:44:27 PM »
I have seen two of these and got one yesterday.
Anyone know anything about these?
It has an Edgewood blade.  Can't find info on that either.
Re: Stanley transitional plane with steel bottom
« Reply #1 on: April 11, 2021, 02:27:52 PM »
Is is a regular bench-size/use plane, but with a steel bottom?  Probably added, if so.
« Reply #2 on: April 12, 2021, 09:28:53 AM »
The wooden body is 15" by 2 1/2"--like a No. 26 or 27.
The mark is poorly done and no No. is visible.
The steel plate is perfectly fitted to the body with a 1/4" upturn lip at the front to prevent gouging and scraping.
Held in place by 16 evenly-spaced countersunk screws.
This--and the other one I saw a few weeks back--are clearly factory done.
Patrick makes no mention of them.
http://www.supertool.com/StanleyBG/stan4.htm
Offline 300man
« Reply #3 on: May 23, 2025, 03:11:39 PM »
I know this is an old thread but...I found a plane today exactly as the OP described. Metal bottom with a fit so precise that it seems to be a factory made plane?
Same counter sunk screw pattern and up turned edge recessed into the front of the plane body.
So that makes 4 LOL!
