Author Topic: I'm sure this has something to do with grounding...  (Read 4470 times)
Offline Frank
« on: November 24, 2011, 09:50:19 PM »
What is it and how is it used? It appears to be made of brass/bronze.
Re: I'm sure this has something to do with grounding...
« Reply #1 on: November 24, 2011, 10:06:13 PM »
I've seen power company linemen use these to hook one wire to another from the ground, turn the thumbscrew to make the connection.  Someone should have the correct name.
« Reply #2 on: November 24, 2011, 10:31:13 PM »
"Hot line clamp"
« Reply #3 on: November 25, 2011, 01:52:44 AM »
good old fashioned stick bug
Offline amertrac
  • ny mountain man
« Reply #4 on: November 25, 2011, 04:47:02 AM »
thats what is is.  all done on hot wires using a hot stick I have several  hot stick tools from my days with the power company.
bob w.
Offline amertrac
  • ny mountain man
« Reply #5 on: November 25, 2011, 05:09:46 AM »
pics are of a hot stick limb trimmer after some modifaction
 64longstep is responsible for the forging work
Offline amertrac
  • ny mountain man
« Reply #6 on: November 25, 2011, 05:12:54 AM »
this is work in progress a hot stick wire raiser
Offline Fins/413
« Reply #7 on: November 25, 2011, 05:31:20 AM »
That would make a heck of a pike.
1959 Chrysler New Yorker
1982 E150 Ford van
« Reply #8 on: November 28, 2011, 09:19:27 AM »
Found this in a Rose Tool post of aCrescent Catalog from the thirties or forties.
« Reply #9 on: November 28, 2011, 10:12:38 AM »
Picture #1 shows
KEARNEY TOOLS #7296 VINTAGE TUBE, PIPE, CABLE CLAMP
Picture #2  shows a current Kearney grounding clamp
« Reply #10 on: November 29, 2011, 03:59:23 PM »
So, in vertical order you got a porkchop
a stickbug
a bar or cabinet stickclamp
BTW, the only time a porkchop instantly releases is when you don't want it to.
