Author Topic: Anvil Shaped Object  (Read 15422 times)
Offline shortfuse
Re: Anvil Shaped Object
« Reply #15 on: December 13, 2020, 09:20:39 PM »
If you can lay your hands on some fork lift tines, they will work as a beginner anvil.  Cut the thickest parts into pieces about 14"-16" long, stack up about four or five pieces, bevel the gaps all around the edges and make deep pen welds.  You can also mod a hay bale fork and weld it to one end for a horn.  Our blacksmith group has a member who makes these and sells them for about $150 apiece.  He uses one with his portable forge at our demos.
« Reply #16 on: December 13, 2020, 11:06:12 PM »
2 more places that I would check, large towing company, one in business for years.  Probably got a welding table with lots of scrap bits.  The other place would be a private dirt moving contractor, one with big bulldozers, scrapers and such.   Oh, are there any small welding/repair shops around you?   These would be my first look sees.
Offline Mike H
« Reply #17 on: December 14, 2020, 05:20:44 AM »
shortfuse-thanks for input,
fork lift tines are something that I hadn't even considered as
possible source for material
JohnK- likewise, appreciate input
we have one large towing outfit just a bit west of us,
will investigate
The ASO is a little further along
got some holes drilled in the bottom
to tie it down to a base, either log chunk
or laminated lumber. I put in a call to the
tree guy that comes out and trims the oak trees we have
to see if he has some log sections I could use as a barrier to
keep people from doing U-turns in my front yard. Might give him
another call to see if he has one piece that would work w/ the ASO.
