Author Topic: Sanding blocks  (Read 1440 times)
Sanding blocks
« on: February 11, 2020, 03:15:23 PM »
I use the standard 3M sanding blocks, as found in your local hardware or big boxy store, quite a bit:
I know they're not always as flat as they could be, but they get the job done for me, and it's easy to install sandpaper on them.
I acquired the little green 3M sanding block at the left at a recent sale (sorry for the fuzzy picture; don't know what happened), and own a couple of the Warner blocks, to the right, and use them quite a bit too:
You can see the profile of the Warner block, useful for some molding and other tight-spot sanding:
If ever I get around to removing rust from some of my hand saws, I may dedicate one of the Warner blocks to that: nice flat wooden "platen."
« Last Edit: February 11, 2020, 03:17:15 PM by Bill Houghton »
Re: Sanding blocks
« Reply #1 on: February 11, 2020, 04:34:01 PM »
I use the  3M type, but also the sanding pads from Harbor Freight.
Re: Sanding blocks
« Reply #2 on: February 11, 2020, 04:43:30 PM »
And I might, too, if I didn't find a sufficient supply of 3M pads at yard/estate sales for 50 cents to a dollar.
Re: Sanding blocks
« Reply #3 on: February 11, 2020, 07:41:33 PM »
I like the size of the green 3M block.  But even though I have a big 3M and the wood Warner type, I always end up using a selection of wood or rubber blocks I've collected over the years.
