Author Topic: one more  (Read 1625 times)
Offline Berryb
one more
« on: December 16, 2019, 09:04:27 AM »
This one is about 10 3/4 inches long. Not aluminum but not iron either. The nut and moveable blade at the end are magnetic though. You can see a tiny pin on the end of the knurled knob that looks like it would be easily broken or worn off, but it is not replaceable. There are no markings of any kind on it. Thanks
Bruce
Offline geneg
Re: one more
« Reply #1 on: December 16, 2019, 09:20:35 AM »
piston ring groove cleaner?
Offline Berryb
Re: one more
« Reply #2 on: December 16, 2019, 10:38:46 AM »
I have heard something similar before, but how does it work?
Re: one more
« Reply #3 on: December 16, 2019, 03:18:29 PM »
I second the motion. Piston ring groove cleaner.
Offline papadan
  • Just an old wrench tugger
Re: one more
« Reply #4 on: December 16, 2019, 03:33:30 PM »
You place the arms around the piston. Turn the head to the bit that fits the ring groove. Then rotate the tool around the piston while holding pressure against the 2 arms. The bit cleans the carbon buildup out of the piston ring grooves.
VWs to D10s, I've fixed em.
Re: one more
« Reply #5 on: December 16, 2019, 06:38:00 PM »
I had a ring groove cleaner, Blue Point I think, but more often used an old piston ring of the same size with good results.
Does anyone still re-use pistons any more ?
