Author Topic: i'll let you guess  (Read 1643 times)
Offline p_toad
i'll let you guess
« on: November 27, 2019, 07:38:37 PM »
and then later i'll post another picture that will answer any questions.  hex shank and i found it in the dumpster  :undecided: :tongue:
Re: i'll let you guess
« Reply #1 on: November 28, 2019, 06:32:44 AM »
Grommet tool?
« Reply #2 on: November 28, 2019, 05:26:03 PM »
Rivet setter ?
Offline p_toad
« Reply #3 on: November 28, 2019, 07:52:03 PM »
i should have put some scale in, but this look from abou 90 degrees from the other pic should answer it.
« Reply #4 on: November 28, 2019, 10:04:45 PM »
What distributor tool has that little slot?  Or is it a tire valve tool?
« Reply #5 on: November 29, 2019, 06:35:59 AM »
I’d go with "tire valve" tool.
« Reply #6 on: November 29, 2019, 09:09:12 AM »
I see the slot now, I would never have guessed tire valve tool, but I like it!!
Offline p_toad
« Reply #7 on: November 29, 2019, 07:12:39 PM »
I'm guessing tire valve tool, too. (no evidence present, like a name stamp anywhere  :sad:).  Never seen one in this configuration before...have the valve caps with the tool built in and that marked Schrader brass tool (previously pictured here) as well as the "X" shaped tool.
Offline JoeCB
« Reply #8 on: December 04, 2019, 10:49:50 PM »
to be a tire valve tool there must be a bore in the end to accommodate the valve stem... is there a bore? And id the diameter correct?
Joe
Offline p_toad
« Reply #9 on: December 08, 2019, 06:18:49 PM »
sorry those angles don't show the bore hole.   Yup, it's the correct size for valves!   :smiley:
