Author Topic: Bonney USA 27020  (Read 2136 times)
Bonney USA 27020
« on: August 17, 2019, 03:07:21 PM »
Hello, I am looking for info on this socket Stamped Bonney USA 27020. 3/8" drive, 2-5/8" long, with what I am calling a captive flat blade screwdriver tip. Carburetor/Valve/Transmission, adjustment tool? Thanks,Lou
Re: Bonney USA 27020
« Reply #1 on: August 17, 2019, 03:48:27 PM »
Can't offer any conclusive help, Lou. Checked my 1967, 1977, 1981, and 1986 Bonney catalogs - nada.
« Reply #2 on: August 17, 2019, 04:57:34 PM »
Looks big for a carb, and, if it's a socket, that seems like overkill for a carb adjustment.  Do the Chevy valve adjusters use slotted screw heads?
« Reply #3 on: August 17, 2019, 05:26:09 PM »
Hello, Guys . Thanks , I looked through a few catalogs too, and found nothing. Bill, well put, that would be a little hefty for a carburetor tool. Regards, Lou
« Reply #4 on: August 17, 2019, 08:23:06 PM »
trans adjusting tool ford-o-matic, used with torque wrench
« Reply #5 on: August 18, 2019, 12:18:30 AM »
Old six cylinder Chevy 216, 235 and 261 engines used stove bolts (round headed 1/4 x 20 bolts with a slot ) to hold on the tappet cover, valve cover, oil pan and timing cover, thus the name stovebolt Chevy. I have a Proto socket made for that use.
« Reply #6 on: August 18, 2019, 07:11:17 AM »
Didn't GM run a oil pump shaft with a slot to the distributor for a few years? This would be to pre-oil the engine before start up.Fords were a hex shaft, Chrysler?
« Reply #7 on: August 18, 2019, 03:20:32 PM »
If memory serves, Studebaker did, in the Champion motor.
« Reply #8 on: August 18, 2019, 11:06:21 PM »
It is a tool for adjusting the bands on a Ford / Mercury two speed auto transmission. A Ford-O-Matic or Merc-O-Matic. 1950'S era stuff.
« Reply #9 on: August 19, 2019, 11:41:21 AM »
Huh
« Reply #10 on: August 19, 2019, 04:05:18 PM »
Hello, Skip. Thanks for the info.!!!!  Regards, Lou
« Reply #11 on: August 19, 2019, 07:13:01 PM »
That was corner kick for goal.   :grin:
