Author Topic: I'm Stumped  (Read 3258 times)
Re: I'm Stumped
« Reply #15 on: March 15, 2019, 06:00:31 PM »
Any one tried to "jeweling" or engine turning with one?a flat pad with a fine grit like lapping compound should work.
I use a round wire cup brush to do aluminum.
Interesting idea.
You could get a kid juked up on sugar, and get him/her to working.  Me, if I decide to engine turning on some metal, I'll probably set up a jig on the drill press.
Offline papadan
  • Just an old wrench tugger
Re: I'm Stumped
« Reply #16 on: March 19, 2019, 10:43:05 PM »
For those who couldn't afford the highfalutin new fangled mechanical ones, the fire starter type worked.
Not quite that fancy or for a model T, but I sure used this type a whole lot of times. Back in the 70s on 4 cyl. flat head forklift engines, I used those a couple times a week.
VWs to D10s, I've fixed em.
Re: I'm Stumped
« Reply #17 on: March 20, 2019, 09:59:28 AM »
Papadan, I bet you--or perhaps your old daddy--have used one of these:
https://www.ebay.com/itm/Vintage-Carborundum-tin-grinding-compound-transportation-collectable-advertising/264234627355?hash=item3d859c711b:g:jg8AAOSwUTZchmJW
I found it Sunday in a Hinsdale G20 ratchet/socket set.  I'm guessing it was quite a trick to make a two-compartment tin back in the day (fine and coarse).
