Author Topic: vintage pattern cutter  (Read 1789 times)
Offline rr
« on: January 27, 2019, 01:42:51 PM »
Ray’s contraption museum.  : this is a K -11 international cutawl , it can cut / chisel and saw pretty much anything . Got this a weeks ago , these were used extensively before CNC cutout machines took over the pattern and die cutout industry . Did a short restoration ,including making my own set of blades and chisels ., also milled two round knobs out of aluminum stock and taped and polished .the motor bearings were locked up , removed and soaked in krill a few days and installed new carbon motor brushes .this things cuts bad to da bone !
Offline rr
Re: vintage pattern cutter
« Reply #1 on: January 27, 2019, 01:45:45 PM »
few more pic's
Offline p_toad
« Reply #2 on: January 27, 2019, 10:44:38 PM »
nice!  never seen one before.   like that index plate.   :embarrassed:
« Reply #3 on: January 28, 2019, 10:25:21 AM »
Would this be used on fabric? never seen one before?
Offline rr
« Reply #4 on: January 30, 2019, 09:28:07 PM »
 the manual says it cuts most anything from wood ,metal fabrics cardboard ,plastics ect,  mostly used for thin materials up to 3/4" or less and you use the recommended chisel ,blade ect . I still rolling around ideas for a project to put it to use
« Reply #5 on: January 31, 2019, 12:03:25 PM »
Cool looking machine, I've heard of them but  never seen one before.
« Reply #6 on: February 01, 2019, 08:51:00 AM »
Stage technicians used to, and may still, love these things.  They're always having to make strange shapes from thin stock for the stage sets, and these are apparently the cat's pjs for that kind of work.
« Reply #7 on: February 02, 2019, 04:43:35 PM »
Is it a rotary tool like a router or does it nibble, saw or knife?
