Author Topic: Hey guys, been a while but just stumbled into something and need some opinions  (Read 9630 times)
Offline Sudsy
So the chuck is very stuck
Any tips on how to get it off ?
Stuck on the spindle threads? or the jaws are stuck?
Spindle threads put it in backgear, push in your spindle lock pin, open jaws of chuck to slide a pc of bar stock or crescent wrench handle and carefully push down on the bar stock. Don't want to shear the pin or break a gear. also make yourself a way guard to protect the lathe bed from the chuck hitting it.
If the chuck jaws are stuck take it off and soak in diesel fuel or kerosene for a week or two to soften up the old grease they may have used.
Offline Sudsy
I decided to do a complete teardown of the headstock assembly, so since I had the spindle with the stuck chuck out, getting it off was easy.
I hit it with PB Blaster last night so it had quite a few hours to soak, and that did the trick. Held the spindle with a bit of scotch-brite pad and twisted the chuck right off
Offline Sudsy
I know, not exactly the right tool for that job, but it's what I have
Tight little machine here !!
https://www.youtube.com/watch?v=y0G_inqH5i4&feature=youtu.be&fbclid=IwAR0Ze2woCDfypzmapXE7QU-yObg5vdGVroID5er4sEEWgESQpV52dMHhEtI
Hello, Sudsy. Looks great!!! And the right tool , is the tool at hand that gets the job done!!!!  Regards, Lou
Sudsy,You have a Milwaukee 181x pneumatic plannishing hammer air motor.  were there any hoops or frames? Here is a pic with the 6 frames I know of.If you go to sell it you probably will get the rest for free and pocket a few bucks!I don't need one have 3 Milwaukee's
FYI a guy is remaking the air motors for about 3k, the lower pin some one is making for a 100$ each, dies no one is make to sell yet.  I made a jig to make new springs but my shoulders are shot. Made about a 6 pins and 40-50 dies for myself. I missed seeing in your second batch of pics.There are 3 knock brands that look similar, M/W sued them and they ceased making them around 1952-3 Snap-on, Thor, Body-Master were the brands, made by Wilray manufacturing
Offline Sudsy
I just figured out what that was and looked it up on ebay - Gotta love surprises like that !I have to get over their again, supposedly there'e a big wood lathe in the basement - I'm not so much a nuts n bolts guy, but I'm very into wood turning
I'm going to look around for any hoops now that I know what they are.
Offline Sudsy
I need to track down a handle nut for the lathe
Anyone know what this type of nut is called ?
You can make one on the lathe, turn down the nut on one side to fit the handle.
Offline Sudsy
Doh !!
Perfect first project
Been there done that, never did figure out where they go? make a spare!
Offline JohnD
Motor on lathe with integral switch is maybe "explosion proof" from a 1940s/50s gas pump. There would have been a sealed cover and hard wiring where the 2 prong plug is hanging out. I've gutted a couple old pumps that were getting cosmetically restored and saved similar ones. Very nice quality motors compared to the cheap ones from washing machines and the like. I used one on a horizontal band saw and rigged the built in switch to shut off at bottom of cut. Sealed nature of motor also prevents cutting debris from entering.
Hey Sudsy!This is my hi-tech spray coolant. a old spray cleaner sample bottle has been working for about 20 years.  I keep a little thread cutting oil in the ibuprofen  bottle with a flux brush nearby. Always good idea to keep a oil can nearby to give the motor and bearings a little lube from time to time.
Offline Sudsy
Appreciate it guys, but I decided to let it go
Sold it for a fair price and a 33 gal air compressor
