Author Topic: More of the old & the new  (Read 1541 times)
« on: December 02, 2018, 09:36:33 AM »
Hello, Progress continues on the garage reno!! Here are a couple photos of the old ceiling, and one of the new ceiling. I need to get all of the ceiling completed so that I can level the floor!!Regards, Lou
Offline international3414
Re: More of the old & the new
« Reply #1 on: December 02, 2018, 11:13:49 AM »
is that dropped,but not really dropped?....good choice on insulation,is it rock wool,.,or whatever they call it
« Reply #2 on: December 02, 2018, 12:10:12 PM »
Hello, You have a good eye!!! The wall angle is nailed to the bottom edge of the exposed ceiling joists, (storage loft above), and then tiles and cross tees across the wall angle. I went with R-19 fiberglass batts in the ceiling joists, and an R-15 , blown-in cellulose & fiberglass batts in the walls. Thanks, Lou
« Reply #3 on: December 02, 2018, 12:28:01 PM »
clever.,.,.,.,,,looks good
« Reply #4 on: December 02, 2018, 02:02:14 PM »
Thanks!!!!!
Offline papadan
  • Just an old wrench tugger
« Reply #5 on: December 02, 2018, 02:22:46 PM »
OK Lou, I just can't stand the suspense, What does finishing the ceiling have to do with leveling the floor? ;-()
VWs to D10s, I've fixed em.
« Reply #6 on: December 02, 2018, 02:28:14 PM »
All of the ceiling parts are stacked on the floor!!!! I don't like to move things twice, so as soon as the ceiling is installed, I have a clear shot at the floor!!!!!
« Reply #7 on: December 02, 2018, 03:40:39 PM »
That makes sense. Is the floor concrete?
« Reply #8 on: December 02, 2018, 04:28:09 PM »
Hello, Papadan. Yes it is concrete, cracked & heaved, also a good coat of lead based paint. I am borrowing a Surface Grinder with a HEPA vac for the safe removal of the paint, the new floor coating would not stick to the old paint. Tried doing it manually , (wet scraping), stuff just would not come off.Regards, Lou
Offline papadan
« Reply #9 on: December 03, 2018, 09:29:42 PM »
OK makes since now! Good luck with that floor job.
