Author Topic: not quite perfect  (Read 1930 times)
Offline p_toad
not quite perfect
« on: November 07, 2018, 12:26:09 PM »
well, it is used...
Re: not quite perfect
« Reply #1 on: November 07, 2018, 01:10:36 PM »
Looks like a good pocket screwdriver. German, H D Smith, or Irwin ?
Offline papadan
  • Just an old wrench tugger
« Reply #2 on: November 07, 2018, 01:41:33 PM »
don't not matter what they look like, they ALL perfect! ;-)
VWs to D10s, I've fixed em.
« Reply #3 on: November 07, 2018, 02:22:31 PM »
I've never tried repairing a pocket with a screwdriver.  Can you explain the technique?   :grin:
If I put a screwdriver that size in my pocket, it would wear a hole in it within five minutes.    :undecided:
Offline d42jeep
« Reply #4 on: November 07, 2018, 02:41:06 PM »
I received this polished shank marked Irwin as a gift.
-Don
Offline p_toad
« Reply #5 on: November 07, 2018, 04:02:07 PM »
Wish i knew.   I gave it a quick rub with a scotch pad (no genie); and no markings either that i could tell.
Any other clues to look for?   At 4 inches long they didn't have a lot of room to write a book.
Offline d42jeep
« Reply #6 on: November 07, 2018, 05:26:52 PM »
Judging by the blade shape it could be a Tobrin. They don’t always have the triangle with the blade length. This is an 11 inch handle stamped version. The German ones have that blade shape as well but most of the ones I’ve seen are marked Germany.
-Don
« Last Edit: November 14, 2018, 07:12:08 AM by d42jeep »
Offline d42jeep
« Reply #7 on: November 13, 2018, 01:16:25 AM »
I picked up this mystery driver on Saturday to maintain my good standing in PHARTS.
-Don
« Reply #8 on: November 13, 2018, 11:53:55 AM »
42- Look closely on the shaft and see if you find markings there curling around the shaft.
Offline p_toad
« Reply #9 on: November 13, 2018, 02:48:07 PM »
"Look closely on the shaft and see if you find markings there curling around the shaft."
I just went and gave it a good going over and don't see any marking on the handle or the shaft.  Being only 4" long perhaps they didn't see a need.   I guess I'll just have to keep it for a while and check it again.   :grin:
thanks...   don't think i've seen that mark on any.
