Craftsman Teardrop Ratchet (1956-1993) Type Study ©
Started by Jim C., July 31, 2018, 09:35:41 AM
0 Members and 8 Guests are viewing this topic.
DadsTools
Screen captures of the TD ratchets from the 1966 Sears Consumer Spring/Summer Catalog and from the same year 1966 Craftsman Tool Catalog.
DadsTools
Here's an image of the RHFT Type 4 handle panel. Kissing Cousin to the TD Type 8 handle!
PowderKeg
So I have a question on the stubby Bowtie shifter lever - have looked over your Type descriptions but not every post in the thread (so maybe you've already answered this and i missed it by speeding thru).  Was that selector switch ever offered from the factory/catalog on standard ratchets?  Obviously used on flex-heads (along with the V-selector in it's time) to avoid interfering with the flex joint, but I have a few standard handle ratchets with it as well.  Is it a safe assumption that those are rebuilds/replacement parts?  I've never seen a 1/4" version, which can be more easily be explained if they were only available on the flexes and in rebuild/parts kits, since there was never a 1/4" pearhead/teardrop flex (or at least one I've ever seen or heard of).  While not Craftsman, I've got a few standard NAPA pearhead/teardrop MDF/Easco ratchets with the stubby Bowtie shifter as well, including a 1/4".
#123
Hey PowderKeg,
Thanks for stopping by the thread. The Type Study presented above focuses specifically on standard raised panel Craftsman ratchets manufactured between 1956 and 1993.  While it doesn't necessarily take the flex head ratchets into account from the same time period, I can say that I've looked at a lot of Craftsman flex head ratchets.  To the best of my knowledge, the standard non flex head Craftsman teardrop ratchets were never produced with the hour glass directional selector.  That being said, I have seen several examples of Cman standard teardrop ratchets outfitted with the hour glass directional selector.  More often than not, I see them on the 3/8" drive models.  Although the Craftsman tool catalogs are not always accurate and frequently depict inaccurate artist renderings that are used from year to year, as pointed out by Dadstools, I haven't seen any catalog evidence of an hour glass directional selector being mated with a standard Cman non flex head ratchet.  It's my opinion that the hour glass directional selectors that are occasionally found on the Cman standard teardrop ratchets are replacement parts.  A little while back, I did come across an unusual directional selector found on a standard Craftsman  1/4" drive ratchet.  Check out the link below.  Let me know what you think.
http://www.papawswrench.com/vboard/index.php?topic=25835.msg147312#msg147312
PowderKeg
Hi Jim,
I must complement you on your thoroughness in researching the Craftsman pearhead/teardrop ratchets - I never realized there was such an extensive trail of changes to those ratchets over the decades.  I've only considered obvious lever and QR design changes/evolutions for inclusion to my USA-made ratchet obsess..., er, "collection" - while I don't see that changing for me anytime soon, you've definitely helped shed light on what I do have and what timeframe they fit in.  I'll also be removing (from the count at least) the couple of standard length bowtie/hourglass shifter ratchets I have, since your study and comments pretty well confirm what I was starting to ponder - that they're the result of repairs/kits and not original offerings.  Although I also have to "dang" you, as now I'm gonna have to find more of the early rounded-corner raised panels to add - never noticed that before (and just realized I have one in 1/4") and they're different enough for me to include - so DANG YOU!!   :grin:
Below is my reply (today) to your unusual 1/4" ratchet thread - I copied it over since that's an older thread.  I think we're on a similar wavelength regarding that ratchet and it shifter origin:
So here's a pic of various 1/4" non-Craftsman pearhead/teardrop ratchets I have, along with an early and later Craftsman to compare.  EASCO eventually made this ratchet design (teardrop) for multiple parties, and those ratchets variously had narrow shifter snap-ring cutouts (narrow like the Type 1/2 Craftsmans) as well as wider cutouts with thicker shift levers as all the later Craftsmans.
My SWAG (hopefully) employing Occam's Razor is this - Sears/Craftsman eventually ran low/ran out of Type 1/2 repair kits.  Other-branded ratchets were in production and some versions utilized similar narrow opening shifter kits with levers that didn't protrude down into the wider shifter cutout.  Instead of retooling to produce the increasingly older and obsolete Craftsman shifter, EASCO substituted the newer style shifter (and pawl if necessary) in kits for narrow cutouts to Sears.  Simply put, it was cheaper for Sears to get replacement kits this way instead of paying to re-start production of an obsolete shift lever design.
The two NAPAs on the left have very narrow inset cutouts for the snap-ring without the levers protruding down into the cutouts like the T1 Craftsman beside, while the rest of the non Craftys have thicker lever ends that protrude down into the wider cutout area, like the T3+ beside them.
It's been a long time since I broke down these ratchets to clean and re-lube them, so I can't recall at all what they look like inside, or what kind/shape of protrusion/indentation they have on the lever to engage the pawl, or how completely they interchange parts with Craftsman ratchets.   I'll also note that the one NAPA with the hourglass/bowtie shifter has an oil hole/ball in the top while all the others do not, so if that's used as a rough dating method, then the narrow shifter snap-ring and cut was used variously on other-branded ratchets for a longer and later time than the narrow openings on the Craftsman Type 1/2s.
So to recap, my SWAG is that your ? ratchet has a later rebuild kit in it from EASCO supplied to Sears as a replacement kit for the repair of early Type 1/2 ratchets that required the narrow snap-ring and non-protruding lever.  This was done as a cheaper option (to Sears) than retooling/re-starting production of the specific Craftsman-style shift levers and pawls for an otherwise obsolete/dated design.
At least that's my nickel's worth...
#125
PowderKeg,
First off, MANY THANKS for the kudos on the Type Study.  I'm glad that you're finding some value in its contents.  Like I've said early on and at various points throughout the narrative, others made contributions, and were credited for them while I was contemplating, writing, editing, re-writing, etc.  That takes me to my second point.
Your detailed analysis and photo seem to strongly strongly support the unusual replacement selector on my 1/4" drive Cman Type 1/2 ratchet.  While DadsTools and I shared your thinking on the topic, neither of us really had any Easco examples to study/observe.  Like I said, I think your analysis makes logical sense and is spot on.  Many thanks again for taking the time to check out the Type Study and furthermore, many thanks for adding some valuable content to it.  In my opinion, it was worth way more than a nickel.  :smiley:
Yadda
I picked up this 1/4 drive Craftsman ratchet this past weekend.  I think it is a Model 13. Needs a little cleaning.  I oiled it and works great.
Hi Yadda,
Thanks for stopping by the thread.  I think you're right, you have a Type 13 version of the Cman 1/4" TD ratchet.  I'm glad the Type Study assisted you in terms of being able to identify your ratchet.  That was the main reason for its creation.  👍
Todd F.
#128
Hey! Take a look at this one. I made the find of the century! Or so I thought. At first glance it's a 1/4", Teardrop, Quick Release ratchet. But, there is no patent information, no part number, pointed "A". This must be the very first Quick Release ratchet ever made!!! Until now, we know that the first QR teardrop ratchet (Type 4) said "Patent Pending" so this must have come before that!!! And only $12 on eBay. I'll be rich!!! But I had some doubts. When I got my hands on it, the first thing I noticed was that the Quick Release button was a little crooked. And, it wasn't quite lined up with the axis of the drive stud. And the Quick Release didn't have the protruding pin in the center of the drive; like the ones on the type 11s and after. Well, I took it apart and found that the hole for the button was off center by over .010" and had a nasty burr around it. So, someone had taken a type 3 Intermediate ratchet and wollered out a hole with their Black & Decker hand drill and shoved in a rebuild kit for a 43185. Probably bought the rebuild kit and found out after he got home that it needed a hole. No problem. So, no fame and riches for me.
Todd F
remember - there's a fine line between collection and obsession
#129
Oh man Todd, I could see where you could have thought you were on to something!  The one dead give away however is the little nub on the selector lever.  See it there at the 12 o'clock position?  Those little nubs started showing up on all Type 13 and Type 14 ratchets, around 1983.  Check out the Type 13 write up.  I have no idea why it's there, but that's definitely a clue that the ratchet you found was not entirely original.  Well, I'm glad you did not pay a premium for it.  Thanks for stopping by the thread.
Yadda
Todd F.
It works fine. One more to throw in the spares pile.
Marf
I have a "Type 10" 1/4" (said not to exist in the type study). 43175, NonOH!
Possible new type (dates conjectural, based on 3/8" and 1/2" versions):
Type 10:  1977/'78  - March 1981, TD, NonOH, LL, QR, FA, -V-, 43175
(represents 1/4" drive size)
Pictures are from the ebay listing. I haven't taken any photos myself. Nor have I disassembled it to see whether it has a plug inside and a straight-drilled hole for the bearing & spring or an angle-drilled hole.
Thoughts?
Hey Marf, that's a pretty good find!  My guess is that you found a Type 9 that for some reason did not get an oil hole drilled at the factory. It could have been a quality control issue.  If you look ahead in the type study at type 11, notice that the 1//4" drive has the oil hole again.  I think your ratchet was incorrectly manufactured and slipped past the quality control department.  I think I'd be more in agreement with you if we had another example of to look at.
Marf
#134
That's an interesting hypothesis, Jim C. However, my understanding is that the hole for the pawl spring and ball bearing was drilled through the oil hole, which would make failing to drill the oil hole implausible.
My understanding is based on reading that on several forums; a link to one is provided below (which seems particularly relevant here as will be discussed below).
The oil port may be only a secondary reason for that hole, the primary one being access to drill the pawl spring hole. (Reportedly, some other ratchet types (from Moore Drop Forging and other manufacturers) simply leave that hole, which was used for drilling the pawl spring hole, open rather than putting a ball/spring oil port there. I can't find a link to such reports at the moment, though, so a grain of salt would be appropriate.) The later, NonOH types must drill the hole at an angle, through the pawl/direction-switch opening (or the main drive gear/anvil opening). The link below includes a picture of an Easco NonOH ratchet demonstrating the angled hole drill for the pawl spring and an oil-hole 1/2" Craftsman one showing the coaxial oil hole and pawl spring hole (that would have been drilled through the oil hole). Presumably, the 43186 uses the angled-hole method, though I haven't taken one of mine apart and confirmed it. (Same would go for Type 10+ 3/8" and 1/2", though I have few of those, my collection focusing on 1/4" drive ratchets, which take up less space.)
Also interesting in the link below is that, for unknown reasons, some oil-hole generation ratchets had the hole plugged and chromed-over. There's an example (a 3/8" ratchet) pictured on the linked page and references to others.
I suspect that my NonOH 43175 has the same thing: a hidden plug inside, installed before chrome plating. I don't know why this was done, instead of keeping the oil hole. Maybe to save the cost of the oil port ball, spring, etc.
It's unknown how many of the 3/8 and 1/2 Type 10s actually have a plugged oil hole and how many have the pawl spring hole drilled at an angle instead. Disassembling several Type 10s and checking for the plug & straight hole or angled hole would be telling.
At some point, I'll disassemble my NonOH 43175 to see if it has the plug and straight hole or the angled hole. Either way, it's a 43175 without an oil hole whereas all the other 43175s I've seen (and all 43185s I've seen) have the oil hole. (It's up to you whether you call that a Type 10 or just an anomaly (of which we so far have only seen the one example).)
Here's the link I referenced above: https://www.garagejournal.com/forum/threads/craftsman-ratchets-with-grease-fitting-in-the-head.55492/
The use of a plug in the oil hole is discussed in posts #9, #10, and #14 (at least).
The angled pawl spring hole Easco is pictured in post #18.
The co-axial oil hole and pawl spring hole (as would have been drilled through the oil hole) is in post #23.
The 3/8" with plugged & chromed-over hole is pictured in post #32.
If you haven't read that 2010 thread before, I think you'll find it interesting. It has some overlap with your research and has some "questions" where you later provide answers.
