Author Topic: Craftsman Teardrop Ratchet (1956-1993) Type Study ©  (Read 208567 times)
0 Members and 16 Guests are viewing this topic.
Offline Jim C.
Re: Craftsman Teardrop Ratchet (1956-1993) Type Study ©
« Reply #135 on: January 17, 2025, 07:33:06 AM »
Hey Marf,
Great write up!  At this time, I’m leaning toward calling your ratchet an anomaly.  However, if these start showing up more often, then I think including it in the Type Study is likely.
Jim C.
Our Go-To Type Study Member
Offline coolford
  • Old as dirt
« Reply #136 on: January 17, 2025, 03:16:51 PM »
Jim C----I figure this is not the place to discuss these Craftsman wrenches, but since I didn't get your message in my messages section here goes!!  These were in a box lot and appear to be mistakes or someone just fooling around.  All three wrenches have not been plated, sizes are 3/8 and 7/16" on the two DOE's and the single combination is 7/16".  The DOE's are vv-44572 and the combination is vv-44694.  The size stamps on the DOE's are on different sides of the two wrenches and are not located in the proper location. Also, the Craftsman name is also offset and one is double stamped on the reverse.  The combination is even more of a mess, as the box end has not been punched out.  Again, the Craftsman name is offset and has been punched too hard as it is very deep, and the reverse is also the same.  Sorry, cannot do pictures as my phone is so messed up I will have to get a new one or send it back to the factory.  I have no desire to keep these wrenches, so if you want them they are yours.  Coolford
Offline Marf
« Reply #137 on: January 17, 2025, 11:54:21 PM »
I went looking and found images of another potential 1/4" Type 10. This one appears to show the suggestions of a chromed-over plug like I mentioned.
Offline Marf
« Reply #138 on: January 17, 2025, 11:59:47 PM »
Note: the 43175 pictured above has apparently had a "QR2" rebuild kit installed (no protruding post). (I've seen many ratchets with "incorrect" parts swapped into them. For example, I have a 43185 with the protruding post (small diameter) like the latest versions of the 43175. One can never be sure what parts are original, other than those that cannot be removed/replaced.)
Offline Jim C.
« Reply #139 on: January 18, 2025, 07:42:47 AM »
Marf,
That’s for sure!  When I was trying to get this type study together, I looked at more ratchets than I could count.  I’ve seen plenty of them with incorrect parts, alterations, and anomalies.  Sears sold millions of them.  There’s bound to be a few oddballs out there.
Jim C.
Offline Marf
« Reply #140 on: January 27, 2025, 09:15:54 PM »
I've now found three 43175 ratchets without oil holes.
