“You can use an eraser on the drafting table or a sledgehammer on the construction site.” - Frank Lloyd Wright
Digging that for sure. have a customer that would buy that in a heartbeat. Wonder what his price is
posted over a month ago
The base is probably filled with sand? With a vise that size cantilevered to that extent the base has to be really heavy. 300 lbs?
Quote from: Yadda on June 22, 2018, 06:52:46 AMThe base is probably filled with sand? With a vise that size cantilevered to that extent the base has to be really heavy. 300 lbs?I bet there is closer to 500 lbs of steel in the base. And if filled with sand, which would be a good idea to dampening the "ringing" from the hollow drum, add another 350 lbs for the sand. My guess anyways.Ken
