Author Topic: Small grinder  (Read 17672 times)
Re: Small grinder
« Reply #15 on: November 12, 2011, 05:28:42 PM »
Stoney, Great grinder!
I found one with a feature yours is missing. Maybe you can add it during your restoration.  OR NOT!
http://www.americanartifacts.com/smma/barnes/b18.htm
Offline Stoney
  • New Market, Alabama
Re: Small grinder
« Reply #16 on: November 12, 2011, 07:46:39 PM »
Cool idea.
Hobbit"
-Thomas Edison
Re: Small grinder
« Reply #17 on: November 13, 2011, 07:40:55 AM »
The one I looked at was mounted on legs.  It had a wooden handle that wnen pulled down rotated a small gear that then drove the blower.  When ypu pulled the handle up it disengaged the small gear from the large gear.  I wish I had bought it now.
It stood free?  Mine's on legs, but short legs.  There's a handle on the gear wheel that drives a pulley that connects to the blower with a belt.  Oh, wait.  I know yours!  I have one of that sort too.  Similar at least.  The bar is attached to the pan and engages a gear that drives the blower with a belt.  That one came from a barn that belonged to a friend's family for several generations.  I have to tinker with it a bit because the palls that drive the blower gear don't always slide into place well enough.  Fun little forge that makes you look more old-timey if you're doing demonstrations.
Offline Stoney
Re: Small grinder
« Reply #18 on: November 13, 2011, 12:07:44 PM »
 Branson the reason that I wanted it was (1) to do demos and (2) it looked more old-timey than a crank type.  But I didn't buy it because it had holes in the pan and I was on short rations having not worked since my surgery in April. Unusual discretion, at least for me.
Hobbit"
-Thomas Edison
Offline Stoney
Re: Small grinder
« Reply #19 on: November 16, 2011, 06:52:04 PM »
Tear down starts Saturday afternoon, if I feel like it, after dialysis.  Will take photos as I go.
Hobbit"
-Thomas Edison
Re: Small grinder
« Reply #20 on: November 17, 2011, 12:13:48 AM »
That's a sickle bar knife grinder, factory made.  I believe I posted a pic of a restored bar grinder here about a month back.
Offline Stoney
Re: Small grinder
« Reply #21 on: November 17, 2011, 07:57:30 PM »
You may be right Aunt Phil but that throws a new wrinkle in the works.  Finding a grind wheel with the right V profile to grind sickle blades.
Hobbit"
-Thomas Edison
Re: Small grinder
« Reply #22 on: November 18, 2011, 12:12:58 PM »
aren't they still available at Tractor Supply?
Offline Stoney
Re: Small grinder
« Reply #23 on: November 18, 2011, 09:37:55 PM »
Yes, but I'll have to check the hole diameter to make sure.
Hobbit"
-Thomas Edison
Offline wrenchguy
    • Wrenchguys videos
Re: Small grinder
« Reply #24 on: December 10, 2011, 06:11:59 PM »
Looks like a factory built tool to me. very nice.
Looks factory built to me too, maybe a luther, but they marked their stuff good.  there were hundreds of hardware houses offering pedal stuff.  good luck
