Author Topic: Oil Change Reminder  (Read 5709 times)
Oil Change Reminder
« on: October 03, 2017, 06:11:00 PM »
Hello, I found this a couple weeks ago, haven't had a chance to post it. Seems to be a vinyl/plastic material, with a 2 digit phone number. Stick pins for mounting to what I am guessing would be a cloth visor? Thanks, Lou
Re: Oil Change Reminder
« Reply #1 on: October 03, 2017, 07:27:42 PM »
  they had cloth visors, seats and  car ceilings.
  perhaps stuck it on the back side of the visor, if it was on the front, when you needed to pull
   the visor down to block the sun, it would fall out into your lap.
   just a thought.
« Reply #2 on: October 03, 2017, 07:33:02 PM »
Cool find!
I just sold some oil change stickers Galena Oil OIL CHANGE SERVICE STICKERS ORIGINAL 1945 Edition
for $8 and shipping.
« Reply #3 on: October 03, 2017, 07:36:12 PM »
I've not seen that type IP but I am quite familiar with the type Papaw just sold.
« Reply #4 on: October 03, 2017, 07:47:10 PM »
This is a local piece, Amecks, where are you?? Mr. Matson was I believe a banker, and owned a car dealership. The more desirable types of this visor mounted reminder were bigger advertising names such as Canadian Club.
« Reply #5 on: October 03, 2017, 07:56:45 PM »
 they also made some with two clips to put on your visor that had small dials to turn to change the numbers,
 those were plastic.
  do any of you folks remember the 45 RPM record players that they sold to install  in your auto ?
  around the 50's.   if you hit a good bump, the needle would jump up. ( good for scrathing the records)l
« Reply #6 on: October 04, 2017, 04:07:49 PM »
Hello, Turnut. This has 5 separate dials that you turn to set the future oil change date. I just used a sharp pencil in the dials to turn them. It only goes to 99,999, that is about 80,000 miles short of my '04 Silverado!!!!!!  Regards, Lou
« Reply #7 on: October 04, 2017, 07:18:52 PM »
 those were plastic.
I think I saw one of those in a car at a car show once.
« Reply #8 on: October 04, 2017, 07:46:26 PM »
  Lou, is there any marks on the dials where someone may have used a common pin ?
 back in the 50's, the catalog of choice was J .C .Whitney, , (if my memory is right)  Warshawsky became J. C. W HITNEY.
    they had everything that you needed or wanted.  Warshawsky startedas a junk yard, selling used car parts,  somewhere I
    have catalogs from both companies.
« Reply #9 on: October 04, 2017, 09:42:32 PM »
I bought quite a bit from J C Whitney in the old days.
I have a string of led lights on  the bed of the truck between the bumper and tailgate ( brake and taillights ) that still work today.
They are still in business.
http://www.jcwhitney.com/
« Reply #10 on: October 07, 2017, 06:50:45 PM »
Hi Lou.  Just noticed this post this morning.  It sounds like you already googled Matson and Scriber.  There's an obituary, apparently there are roads named Matson in the area, and another link may be existing relatives in the area.
If it is not very sellable, maybe one of his relatives would appreciate it?
http://www.rootsweb.ancestry.com/~nyononda/OBITUARY/fbmatson.html
https://www.peoplefinders.com/name/hubert-matson
« Reply #11 on: October 08, 2017, 05:49:15 AM »
Hello, Al. I have found family pieces before, and usually the family is not interested. I even tried to return a set of Military Dog Tags, and the family did not want them. But I will look into it. Thanks, Lou
« Reply #12 on: October 24, 2017, 02:20:17 PM »
do any of you folks remember the 45 RPM record players that they sold to install  in your auto ?  around the 50's.   if you hit a good bump, the needle would jump up. ( good for scratching the records)l
I thought you were supposed to play records on those when you were parked.  Nice, romantic records.  While you were parked somewhere you could neck.
