Author Topic: Local Museum donation yard sale find  (Read 2027 times)
Offline moparthug
« on: September 15, 2017, 03:58:35 PM »
My local Museum and Historical Society (Woodville Museum, Rogue River, OR.) has a donations yard sale and fund raider once a year, and this year I was first in the gate!
From top to bottom-
Ford M-40-17017
Herbrand  255 offset single-box brake wrench
Herbrand 2377 deep reach distributor wrench
Proto 216 brake plyers
PWA mystery tool
Proto 6435 (exhaust manifold?)
Snap-On S-8564A (date code 1958)- 1958 to 1962 Lincoln Distributor wrench
Snap-On S9476A (date code 1958)- 1958 to 1970 Chrysler Distributor wrench
The overly pleasant elderly lady working the check-out table thought this was a $5 collection of tools, so I handed her a $20 and said keep the change as a donation to the museum.
The only tool I can't ID is the PWA off set 1/2 drive extension, it's marked with PWA598-1 PWA 607-1, and seems to have an elongated letter O as a forge ID. Is there a part missing off the ring end of this tool, or is it just for a slide through cross bar?
Rogue River, OR.
  • Administrator
Re: Local Museum donation yard sale find
« Reply #1 on: September 15, 2017, 04:48:22 PM »
Our newest member, Cutman, may know about that PWA tool.
Offline mvwcnews
« Reply #2 on: September 16, 2017, 02:59:30 PM »
Is is part of an aircraft engine maintenance set (Pratt Whitney Aircraft)? Some of the wrenches for radial engine work took on very strange elongated shapes.
Offline Cutman
« Reply #3 on: September 19, 2017, 05:09:02 PM »
 Hi guys, as you say it's a half inch extension then my guess is that it's for removing cylinder nuts as they connect to the engine body. Those often took very weird shapes.
We can do a search for that number tool, but as it's a three digit instead of a four digit number I would bet it's for an older  R – 985, instead of an R – 2800, R-2000 or  an  R- 4360.
That's all I got off the cuff, want me to check further?
Best, John
Offline moparthug
« Reply #4 on: September 20, 2017, 11:35:33 AM »
Hiya John, my big question is about the ring end, is there something missing or was this just for a leverage bar to be put through? The tool shows no sign of the ring end being abused, it's clean and unmolested, I would think if a cross bar was used it would show some signs of use. Aside from that it's my usual OCD kicking in by not knowing exactly what-where-when-why- and how a tool is used.  :smiley:
Rogue River, OR.
Offline Cutman
« Reply #5 on: September 22, 2017, 07:31:56 PM »
 Hi Mo Parthord,
Will you look to be correct, if you Google PWA 598 to find a reference from the Australian Navy which has the 598 listed. Looks like that slot would take French handle of some sort. Hope that helps, John
Offline moparthug
« Reply #6 on: September 23, 2017, 09:48:36 PM »
It took some digging to find the link but that was great, thanks for finding that!
Rogue River, OR.
« Reply #7 on: September 25, 2017, 07:41:03 PM »
OK, as part of my continuing education program: what's a French handle?
Offline Cutman
« Reply #8 on: September 26, 2017, 04:10:42 PM »
Oi.  meant WRENCH handle.  D@@@ Autocorrect!
LOL Cutman.
« Reply #9 on: September 26, 2017, 05:09:17 PM »
LOL Cutman.
You never know.  I found a reference the other day in some 1907 shopnotes to "Algerian lute," which clearly did NOT mean this:
but rather luting, which is a (perhaps archaic) term for what I was taught to call "acky-pucky," meaning a putty like stuff to stick things together, fill holes, etc.  But Algerian?  Not sure what the Algerians knew in 1907 that made their luting different.
