Author Topic: Snap-On toolbox question  (Read 1991 times)
Offline swervncarz
« on: August 17, 2017, 02:06:34 PM »
I have a question for a Snap-On collector. Is this a Snap-On toolbox or did someone just put the Snap-On logo on it?
Re: Snap-On toolbox question
« Reply #1 on: August 17, 2017, 02:28:50 PM »
If you don't get an answer here, you might try here: http://www.collectingsnapon.com/forum/index.php
« Reply #2 on: August 17, 2017, 02:53:10 PM »
If you look on the back on the lower right corner there should be the date of manufacture and the city. I think it also says Snap-on, if it is one. Look close as the stamping is hard to see.
I can't tell by just looking at it.
Offline swervncarz
« Reply #3 on: August 17, 2017, 04:29:53 PM »
Thanks for the info, I will check when I get home
« Reply #4 on: August 17, 2017, 09:51:23 PM »
I am quite sure that it is a Snap-On toolbox and Mike is correct about the stamping.
Should be a kra-377 I believe and there should be a cover that fits that lower section.
« Last Edit: August 17, 2017, 09:54:22 PM by bill300d »
Offline swervncarz
« Reply #5 on: August 17, 2017, 10:16:13 PM »
Thanks, I looked on the back but cannot see anything. Looks like there's a couple layers of paint on it, probably covered up if it's there.
« Reply #6 on: August 17, 2017, 10:28:34 PM »
yeah if there is a couple layers of paint you probably wont be able to see it. If you go to collectingsnapon.com and find the 1967 catalog and look on page 9 you will see one like the one in your pic.
Offline swervncarz
« Reply #7 on: August 17, 2017, 10:47:54 PM »
Thank you, I was just trying to confirm that it was Snap-On, I have it on Craigslist & got a message from someone telling me that he thinks it's not Snap-On & actually a Craftsman box. I just wanted to make sure I don't sell someone the wrong thing!
« Reply #8 on: August 18, 2017, 07:22:27 AM »
It looks like this box...
Which is made by Metal Box and Cabinet Co.   They made the same box for Snap-On.  There's supposed to be a panel to cover the front which lifts out and hangs on the back of the cab on two welded tabs.  The yellow box here also has a shelf.
I restored the top box and painted it the original orange color.  The bottom cab is very rough but will get a clean-up, new wheels and quicky paint job.
« Reply #9 on: August 18, 2017, 04:02:19 PM »
I just checked my PAR-X / SNAP-ON tool box and the box information was on the back in the middle of the panel. Mine is  marked,
PX-1B
SNAP-ON TOOLS CORP.
KENOSHA WISC. USA 68
0388933
Offline swervncarz
« Reply #10 on: August 18, 2017, 05:01:01 PM »
Ok, I will have to check again, I stripped some of the paint off on the bottom right corner but didn't see anything. I will have to look in the middle!
« Reply #11 on: August 18, 2017, 05:25:19 PM »
It might help to use a bright light and look from different angles as sometimes that's the only way it will be seen.
« Reply #12 on: August 18, 2017, 06:20:08 PM »
The drawer pulls on your bottom box is the same style as the drawer pulls on my top box.
