Author Topic: 1930's Plomb Los Angeles 4520 4521 4522 Bolt Stud Puller Extractor  (Read 2187 times)
Offline UncleBill
Pretty cool item found at a sale this morning with lots of other goodies.  I couldn't find one listed so I thought I would share it just incase you wanted to see one.
Plomb catalogue 1936
Detachable Stud Puller
Latest development in stud pullers. No 4520 handles all pleasure cars and many trucks. 1/2" square drive. Works simply and easily. Slip over stud, push in wedge with fingers, and turn. To release instantly, tap tool. Won't freeze on stud like eccentric type pullers. Turns in smaller circle; works close to dash.
4520 $2
4521 $.50
4522 $.50
« Last Edit: June 03, 2017, 06:17:09 PM by UncleBill »
Re: 1930's Plomb Los Angeles 4520 4521 4522 Bolt Stud Puller Extractor
« Reply #1 on: June 03, 2017, 08:03:51 PM »
That is a nice design.  I've got one, and hadn't thought about the fact that it would work in tighter spots.
I take it the screw is there for storing the wedges.  I can't recall how mine stores them.
Offline UncleBill
« Reply #2 on: June 03, 2017, 08:45:45 PM »
That's right.  The screw just holds the wedges inside the socket so it stays together as a set.
Offline UncleBill
« Reply #3 on: June 03, 2017, 08:49:19 PM »
Also I have it set up incorrectly in the 3rd picture.  Your supposed to insert the broken bolt through the end hole and then insert the wedge through the side hole and push down until it locks on the bolt threads then crank the ratchet to free the bolt.  I tried it on a loose bolt and it grips pretty tight, so it seems like it would work fine.
« Reply #4 on: June 03, 2017, 10:09:13 PM »
My Proto version has a clevis with a spring loaded ball to keep the wedges in the housing. I have owned mine for over 35 years.
Offline JoeCB
« Reply #5 on: June 04, 2017, 08:08:45 PM »
I like it,  nice find. I got a chuckle out of the description "works close to the dash". in 1936 I guess that they still called the firewall the "dash board" ... horse buggy terminology. The thing inside the car was the instrument panel.
Joe B
Offline UncleBill
« Reply #6 on: June 04, 2017, 10:58:15 PM »
Luckily the original owner was very descriptive on how it worked.  It was a good thing because when I first saw it I couldn't really figure out what the use was considering it looks like your regular socket at first glance.
« Reply #7 on: June 05, 2017, 09:02:15 AM »
Joe B
Like!
