Author Topic: Evaporust Question  (Read 3452 times)
Evaporust Question
« on: May 25, 2017, 11:13:22 AM »
I have a gallon of Evaporust I bought more than two years ago. Is it still OK to use? I also have some that has been used  but saved in the original jug-Same question.
Re: Evaporust Question
« Reply #1 on: May 25, 2017, 11:55:09 AM »
I don't have the answer to your question, but I did not like the product myself due to how messy it is and it's cost. I use white vinegar and find it works quite well and thats all I have to say about that.
« Reply #2 on: May 25, 2017, 01:01:22 PM »
I also use vinegar, but wonder if the Evaporust is still good. Guess I will just have to see.
« Reply #3 on: May 25, 2017, 02:57:17 PM »
Papaw
    I would have to believe that the unused product would be good yet. The previously used product could have a shelf life if not kept in an air tight container I would think.
« Reply #4 on: May 25, 2017, 02:58:53 PM »
I would try it. For what it costs you don't want to throw it away.
« Reply #5 on: May 25, 2017, 08:59:40 PM »
 I have used older jugs of it with no problems.
  I also reuse Evaporust, I strain it when pouring it back into the jug.
Offline Bad 31
« Reply #6 on: May 25, 2017, 09:40:13 PM »
I keep mine in a plastic container with a positive locking lid. The "destructions" say if the product gets to low, just add more water. So maybe the chemical or whatever makes it work hangs around. I personally like the stuff.
Offline lauver
  • Belton, TX
« Reply #7 on: May 26, 2017, 04:22:36 PM »
Papaw,
I've had good luck using Evap-O-Rust that has been stored for years, both new and previously used.  I have always filtered the used EOR before returning it to the container.
I also go to some lengths to remove contaminants (i.e. grease, oil, dirt, and loose rust or chrome) from any tool that headed for an EOR bath.
You can always run a small test with a small rusty item and a small amount of EOR.  You have nothing to loose.
« Reply #8 on: May 26, 2017, 04:57:47 PM »
This all good to know. Generally I just use a brass wire brush and some sort of thinned oil pb blatster, liquid wrench, mmo etc. If that isn't enough to satisfy me then in the electrolysis tank it goes.
« Reply #9 on: May 26, 2017, 08:29:56 PM »
   one thing that I failed to add, is that I always shake the jug before using it.
   does it help ???   just one of my habits,  I do the same with anti-freeze.
« Reply #10 on: May 29, 2017, 07:10:08 PM »
I just bought my first jug a few weeks ago. The stuff works good........actually it works TOO good. Now I've got a hundred-year-old tool with a bright shiny silver metallic finish on it.  :-\
So now what is a good way to get some "instant patina" back onto it?
« Reply #11 on: May 29, 2017, 08:40:27 PM »
  you want patina ???
   just use it for the next 50 years, that should get you some patina.
    just a thought.
Offline kwoswalt99
« Reply #12 on: May 29, 2017, 08:51:18 PM »
  you want patina ???
    just a thought.
I'm guessing most of the members of this site aren't going to be around 50 years from now, but I like your answer.
« Reply #13 on: May 29, 2017, 08:53:53 PM »
one of the Saturday morning car shows on Velocity had this very question in one of their paid for segments. They showed it dried up in a lump. added the same amount as originally used good as before. They showed it black like old motor oil that is when it is wasted.  Which show? performance tv?  (I think) The blonde lady has been on a few years she was on so I think that is the shows name. I do not know if it was a new show or a repeat.
http://masterstvshows.com/shows/performance-tv/2016-series/
Offline stanley62
« Reply #14 on: June 05, 2017, 10:44:40 PM »
I soak tools is EOR for an hour or so and then brass brush tool off.  Rinse with water and blow dry and WD40 bath.
Patina stay put but surface rust is gone...
