Author Topic: Shoemaker iron  (Read 1320 times)
Offline t115145
Shoemaker iron
« on: April 22, 2017, 11:59:55 AM »
Is anyone here interested in some shoe lasts, and related equipment?  Kind of rusty, but I can wire brush it and paint if that helps.  I don't know what it's worth, but I'll make you a good deal.
Thanks.
Re: Shoemaker iron
« Reply #1 on: April 23, 2017, 08:45:49 AM »
Can you post a photo or two of what you have?
Offline t115145
Re: Shoemaker iron
« Reply #2 on: April 23, 2017, 05:13:04 PM »
Plyer,
I'll try, I have almost no luck due to the BIT limit.
Re: Shoemaker iron
« Reply #3 on: April 24, 2017, 10:21:57 PM »
Try reducing the size of the photos, here's how:
It seems like every computer is different, but basically you need to right-mouse-click on the photo, and select the "Open With..." option. Then choose the "Paint" program, which is pretty basic, but will work fine.
Then choose "Resize" and make sure the "Percentage" and "Maintain Aspect Ratio" boxes are checked. Depending on the size of the original photo, you might have to choose a number like 25 percent to get the photo small enough to fit within the BIT limit for posting.
Experiment a little bit. It's not that hard, once you've done it a time or two. Hope that helps, good luck!
