Author Topic: Hand Crank  (Read 1486 times)
Offline t115145
Hand Crank
« on: March 11, 2017, 11:22:36 PM »
I'm looking for a hand crank with a 7/8 square drive to operate my slip roll.  Any ideas about where to find one?
Re: Hand Crank
« Reply #1 on: March 12, 2017, 08:08:17 AM »
I ended up making ones for my slip roll and circle cutter. Used a flat bar, a broached short round bar stock and longer bolt and a handle grip that spins on the bolt
Re: Hand Crank
« Reply #2 on: March 12, 2017, 08:52:28 AM »
Get an old hand crank from a woodstove and weld a 12 point socket on the end.
Re: Hand Crank
« Reply #3 on: March 12, 2017, 12:38:40 PM »
I need to buy or make one for my old Briggs & Stratton industrial engines. They range from to 4-1/2 hp to 9 hp and all use the same crank handle. They are rope start now, but have the right hub for a crank handle. They can also use a starter/generator. I am slowing collecting parts to build a 1/2 scale model T Ford using one of the 9 hp engines with a hand crank and a starter / generator.
EvilDr235-1/2
