Author Topic: A motivator  (Read 3483 times)
A motivator
« on: February 21, 2017, 09:26:19 PM »
John Harper ( WVTools.com ) has sent me an H D Smith "S"  660 screwdriver that needs new scales. I haven't done this in a while, so I am going to find some nice wood and make new scales for it.
Here it is as I received it today in the mail.
« Last Edit: February 21, 2017, 09:28:15 PM by Papaw »
Re: A motivator
« Reply #1 on: February 21, 2017, 09:37:32 PM »
  ah, time to let the brain cells get their exercise.
  maybe someone will donate an exotic piece of material.
Re: A motivator
« Reply #2 on: February 21, 2017, 10:33:31 PM »
I have begun a large one (sans ears).
I don't know about you, but is very easy to set it aside for another day.  And another....
Re: A motivator
« Reply #3 on: February 21, 2017, 10:39:51 PM »
I have set too many things aside lately. This will motivate me to get it done. If I remember , I will take progress pictures.
I have some walnut readily available. I need to cut it and see what the grain looks like.
Re: A motivator
« Reply #4 on: February 21, 2017, 11:51:30 PM »
Good wood on the cheap and this is the perfect size.  Find an old trophy at a thrift shop.  They unbolt easy and usually have some nice pieces of wood.   Never owned one of those screwdrivers, because I never found one!
Re: A motivator
« Reply #5 on: February 22, 2017, 01:10:44 AM »
John,PM me your address  and I'll send you one that will start you on your way to being a PHART.
Skip
Re: A motivator
« Reply #6 on: February 22, 2017, 02:13:15 PM »
Skip
That's the ticket! Get another sliding down the slippery slope!
Re: A motivator
« Reply #7 on: February 22, 2017, 03:57:53 PM »
what wood was used originally?  I've got a couple of ton of hackberry here for firewood.
Re: A motivator
« Reply #8 on: February 22, 2017, 07:56:48 PM »
I've never seen that design - very nifty.
Re: A motivator
« Reply #9 on: February 22, 2017, 09:31:56 PM »
I don't think the catalogs ever said what kind of wood was used. They only said it was waterproofed.
Offline RedVise
Re: A motivator
« Reply #10 on: February 23, 2017, 08:42:29 AM »
Good title !  A couple of years ago I traded Scott G a beryllium ratchet for some assorted wood blanks to make Perfect Handle scales out of...
Sadly, today there they sit. Just havent made it to the top of the priority list.
Looking forward to seeing pics, the write ups on this process makes it seem easy, however the writers always have a pretty fair amount of wood working talent to begin with.
Brian
Re: A motivator
« Reply #11 on: February 23, 2017, 03:01:19 PM »
I have replaced the wood on a few, and think there is one with wings in a box someplace.  Am willing to tackle another, just found a great N.O.S. rasp.
Re: A motivator
« Reply #12 on: June 25, 2017, 06:50:32 PM »
120 days since the last post and I have finally done something with the screwdriver!
Both my sons are heavy into Cosplay and ComicCon stuff and have "build days" when they can.
 I was going to work on the screwdriver last month but life again got in the way.
Today they had a build day and I was able to get things situated to work with them.
I did use the number 2 son's tailed apprentices , but that's OK for now. I trimmed and cut the walnut from an old barstool using a bandsaw, then pressed it into the cavity to fit it properly. Then after more cutting and sanding, I pressed them in place temporarily, hoping to rivet them later. I may just glue these in, though, since it is an experiment.
A bit of sanding got me close enough to a good fit. I will now try to find time to stain or somehow get an old look to the scales. Oil? Stain? Heat? What?
Not a Scott G class job, but for only my second real try, I'll take it.
Re: A motivator
« Reply #13 on: June 25, 2017, 07:18:45 PM »
Very interesting.  I look forward to seeing the end result.
Consider using rust to make a natural dark stain.
« Last Edit: June 25, 2017, 07:24:58 PM by Yadda »
Re: A motivator
« Reply #14 on: June 25, 2017, 07:30:54 PM »
That's a good idea. Maybe some of the old vinegar left from another project?
