Author Topic: Old saw from old carpenter  (Read 1605 times)
Offline In_a_good_mood
« on: February 16, 2017, 01:36:26 PM »
Hello,
I've bought these handsaws from a retired carpenter. They'll arrive next week. I don't know their makers' name, though I suspect the upper one is a Greaves and the middle one is a Goldenberg.
My worry, that I want to share with you and ask for your advice, is the condition of the middle handsaw, sharpened too much and almost without steel at the heel. I see the carpenter has stopped sharpening the heel section thus creating a slight blade curvature.
I think this will not be of good use the way it is, so I thought to replace the handle making an open one, to free space so I can make the blade straight again at the heel with a file, and reshape these teeth portion. Is that a good idea?
Thanks for your attention!
Re: Old saw from old carpenter
« Reply #1 on: February 16, 2017, 02:21:11 PM »
I'm having trouble seeing the picture...that is, I don't see a picture.
As to your question, why not remove the handle, reshape the saw plate, and do all the sharpening, then replace the handle?  That way you can either re-use the existing handle or make a new one, whichever works out better for you.
Offline kwoswalt99
« Reply #2 on: February 16, 2017, 09:24:08 PM »
I would just remove the teeth from that portion of the blade, they're not useful there anyway.
« Reply #3 on: February 17, 2017, 11:42:38 AM »
Thanks, Bill Houghton. Very good idea. The handle is actually good.
Posting again the pic so you can see,
Yes, I think I can save time by doing this and testing whether this will cause trouble or not. But I think that portion is not so much relevant anyway.
