Author Topic: What is it  (Read 4589 times)
Offline lowie_fuzz@yahoo.com
What is it
« on: November 29, 2016, 08:12:02 AM »
Hi found this in a box I check E/bay & Google with no luck.
Re: What is it
« Reply #1 on: November 29, 2016, 08:41:07 AM »
 ???  does that outer sleeve have pipe threads ??   or the same as a spark plug thread ??
 what size is the sleeve diameter ?
 how long is the bolt ???
 just looking for some clues.
Re: What is it
« Reply #2 on: November 29, 2016, 11:08:14 AM »
I think it is some kind of puller. Look at http://kar.ca/ KAR Industrial.
Offline couchspring
  • council bluffs,iowa
Re: What is it
« Reply #3 on: November 29, 2016, 11:21:00 AM »
GM a/c compressor pulley tool ?
Offline p_toad
Re: What is it
« Reply #4 on: November 29, 2016, 07:19:33 PM »
If that thing is threaded all the way thru; and the end is threaded to go into the spark plug hole...my guess would be a stop for checking for top dead center when setting up a new timing on an engine.
Re: What is it
« Reply #5 on: November 30, 2016, 09:40:29 AM »
Re: What is it
« Reply #6 on: November 30, 2016, 10:46:33 AM »
 I believe that couchspring & lostmind are on the right path.
 google;  A/C   clutch hub remover tool.
Re: What is it
« Reply #7 on: November 30, 2016, 11:17:08 AM »
I'm leaning towards the TDC idea. Haven't seen one in years but that's how I remember them.
Re: What is it
« Reply #8 on: November 30, 2016, 02:23:15 PM »
I have used TDC finders, but don't think I would use one that is threaded and might be set too deep and stop piston travel before TDC.
