Author Topic: replacing tires  (Read 2919 times)
replacing tires
« on: October 19, 2016, 02:45:32 PM »
 Had my local tire guy (I trust him like a brother) check the tires on my 2010 Escape. Has 98300 plus miles on it and I' m getting some tire noise. He said the tires were made in 2009 and were the original tires . I thought they were but at my age  I could have forgot replacing them. Hate to replace things before they are worn out. He recommended replacing them and to not go out of town till I did. Guess I'll agree. What brand do you guess they are ?
Nother subject Any one know this things proper name. Trademark is an S in a diamond. I'm guessing its a masons tool for insertion in a mortar joint to string a line to keep wall straight but thats only a guess.
« Last Edit: October 19, 2016, 02:55:30 PM by jimwrench »
Re: replacing tires
« Reply #1 on: October 19, 2016, 02:52:32 PM »
You've got 98,000 miles on a set of tires on a vehicle that won't be built for four years?  Man, you must put a LOT of miles on your vehicles!
At 98,000 miles, those tires are probably pretty thin; and living where you do, you need to think about snow, and traction in snow.  Are the wear marks showing?  Plus, the manufacturers recommend seven years as kind of the outside lifetime for tires.  So, yeah, I'd stay close to home and not drive fast until you can get them replaced.
Can't help on the whatsit.  For all I know, it's a leatherworking tool of some kind.
Re: replacing tires
« Reply #2 on: October 19, 2016, 02:57:53 PM »
Sorry Bill my proofreader only works on days ending in Y. Tis indeed a 2010
Re: replacing tires
« Reply #3 on: October 19, 2016, 02:59:34 PM »
It might be a concrete form pin. Used to attach forms together at their edges.
Re: replacing tires
« Reply #4 on: October 19, 2016, 07:31:21 PM »
Well, that's better than if it were a 1920 truck.  Or maybe not.  I'd walk across the street and down the block to own a 1920 truck.
Re: replacing tires
« Reply #5 on: October 19, 2016, 08:08:12 PM »
I wish I got that much out of my tires. Ide still have money in my pocket for a while longer.
I just spent 900 bucks last month on new tires.
Re: replacing tires
« Reply #6 on: October 19, 2016, 09:50:12 PM »
Since retirement I haven't had to buy new tires in a while, but I always bought Cooper or Kelley SUV tires that give me 75-80 thousand miles.
Re: replacing tires
« Reply #7 on: October 20, 2016, 07:41:58 AM »
Yeah, I'm amazed that you got 98K on a set of tires.
My guess is Firestone since they have had a relationship with Ford.  Second guess would be Bridgestone (Japanese company) since they apparently now OWN Firestone.
Re: replacing tires
« Reply #8 on: October 20, 2016, 11:39:03 AM »
 Did I mention they are Michelin.
Re: replacing tires
« Reply #9 on: October 21, 2016, 08:29:38 AM »
jimwrench: "What brand do you guess they are ?"
Ha! I thought we were being quizzed!  I guessed wrong or I would have been asking what the prize was.
Michelins certainly have a good reputation.  I just read that at some point in time they purchased the BF Goodrich brand name.
Offline J.A.F.E.
Re: replacing tires
« Reply #10 on: October 21, 2016, 10:49:56 PM »
Far as I know Firestone tires relationship with Ford ended with early Explorer/late Bronco II in the early 90's with the tires that kept delaminating. I think Michelin is the current supplier.
Probably best to replace them if the date code is 2009 rubber gets brittle over time. The work van I drive is a 2012 and the tires were already starting to crack on the sidewalls even though they were within the date code range and for some reason the right rear was the worst - this is the result one hot day about 50 mph on the freeway.
Still plenty of tread left.
All my taste is in my tools.
Re: replacing tires
« Reply #11 on: October 22, 2016, 10:28:42 AM »
I've had to replace a set of tires recently due to vandalism. Got the one tire replaced free under warranty, felt it was foolish to have 3 other worn tires with one new.
Tires I hear have a time replacement as well as mileage. My local shop won't repair a tire that is passed a certain age even if the tread is still acceptable. In AZ the rubber tends to dry out so tires with low mileage are still considered as needing replacement. Don't know how much truth there is to that, but, that's what the tires boys tell me.
