Author Topic: Great Northern Flea Market - several Whose-Its?  (Read 1966 times)
« on: June 05, 2016, 04:33:23 PM »
In Adams Center NY.  We went to look for something they had advertised - which we did not buy.  But outside in the rain was a table and some tool boxes with wrenches and the usual junky stuff.  I was surprised these weren't inside the building with tags tied to them saying $2, $5, $10.
Left to right
JP Danielson - just like the ones on AA 1930's to 42 - These are going in my plier drawer!
Thin Japan pliers - also keeping for a tool kit.
The rest of all this stuff I will likely sell off...if they're of value...
Utica Duckbill pliers
Moore pliers
Wrench with a spring clip in the offset square Pat April 28 1903 stamped BABCOCK http://datamp.org/patents/displayPatent.php?pn=726782&id=24800
Oneida No.1 box wr ???
Rusty Bonney open end with SAE markings
Wrench DOE 3/4 5/8 marked only Forged USA
IHC P1183 - is this in demand?  What was it for?
INOX? PUROX #6402 gas cyl wrench?
Short heavy wrench with odd curve 15/16 1-1/16 both ends no markings
Heavy plated alligators - small is marked in an oval "Bonney Vise & Tool Works" "**CA PA" in center of oval and across the bottom something followed byt the date "1876"
The large alligator - has a big "3" stamped in the middle and the mid other side has a circle about 1/2 round with letters only two of which might be readable.  small Bonney shield - just able to be read.
And an 11 inch Auto with no other marks - I think it will clean up and work OK, jaws not bad, varnish on handle
Thanks for lookin'
Edited 6/6 10PM
« Last Edit: June 06, 2016, 08:47:14 PM by amecks »
Re: Great Northern Flea Market - several Whose-Its?
« Reply #1 on: June 05, 2016, 08:32:24 PM »
 I would believe that the Babcock would be a good seller.
 does the Moore pliers also say "Springfield, Mass. ?
« Reply #2 on: June 05, 2016, 08:42:27 PM »
The Moore pliers only have the M Circle logo.  No knurling on the handles and the jaws are fairly worn.  Somebody welded the nut so there's no adjustment.  They're very plain and in sad shape.
Offline lauver
  • Belton, TX
« Reply #3 on: June 13, 2016, 10:31:11 AM »
amecks,
the unbranded 3/4 x 5/8 DOE on the right side of your 1st photo was made by Barcalo.
« Reply #4 on: June 13, 2016, 03:44:45 PM »
I think AA calls it a Geometric?
Cleaned up, it will be attractive.
« Reply #5 on: June 13, 2016, 06:35:49 PM »
Love the JP parrot head pliers. They come in handy at times.
« Reply #6 on: June 16, 2016, 07:56:37 AM »
So that's a Barcalo wrench?  I knew I had seen them before here on Tool Talk but did not remember who made it.  I had use for a 3/4 wrench in my welding kit so I cleaned it and painted the recessed parts blue, adding a light clear coat.  It looks good.  The cad plating is long gone - I saw no sign of it.
Thanks
