Author Topic: 10" Inca Table Saw for Sale  (Read 2481 times)
Joseph Quinn
  • Guest
« on: March 16, 2016, 04:51:56 PM »
INCA 10”   Cabinetmakers table saw  341.018  Model 259. 20mm (.784 in.) arbor
          with Inca hardwood stand , motor (1.5 HP, 110 v/220v Continuous Capacity).
Motor wired for 110v.
Accessories:
Table Extension Guide Rails: 39.5 in. length and extra extension Table
Mortising Apparatus Table with two Hold down Clamps
Device for Cutting Tenons
Hold down with wheel for ripping
Drum Sander, 1.75 dia.
Abrasive Disk, 6 in. dia.
Wooden Guide for Lock Joint Work
Mortise Drill Bits:  4 ea. : 6mm, 8mm,10mm, 12mm
Milling Drill Bits:  2 ea.: 9/32”, 3/8”
Wobble washers,13/16 arbor (4 ea.)
Saw Blades: 20mm (.784 in.) arbor (most blades are dull)
                        Dado Cutter: 6mm (.236 inch) width
                        10” chrome nickel 3 ea. (100, 75, 36 teeth)
                          7”     “             “     1 ea. (200 teeth)
                          7.25“ -24 teeth     Carbide teeth
                          7-7/8”  Carbide teeth
                          10” 4 ea. 40 teeth  Carbide teeth
                          10”  one ea. 24 teeth  (new, 5/8” arbor)   Carbide teeth
                          10” sanding dish, .784 arbor
Table Inserts (2 ea.: 1”, 9/64” throat)
Only $500.00.  Buyer makes arrangements for pickup and shipping.  Sale of home workshop due to age (86).  This extraordinary saw has served me well over the years, and has its war wounds. Needs to be disassembled, lineage cleaned, and reassembled (take-down diagram of individual parts included in manual): adjustments are difficult to turn; suspect packed sawdust (or I am weaker with age). Location;  Independence, Oregon
Re: 10" Inca Table Saw for Sale
« Reply #1 on: March 16, 2016, 10:35:54 PM »
We need to know what payment method you will accept.
