Author Topic: 8' Level  (Read 1751 times)
8' Level
« on: November 21, 2015, 12:39:26 PM »
Znamien's thread got me wondering about this 8 footer, what was it used for?
Been in the rafters for years,
Re: 8' Level
« Reply #1 on: November 21, 2015, 08:05:37 PM »
Before the laser, long levels and piano wire were the favored method of establishing a long plane.
The 8 foot bubble stick could get a lot of work done before somebody could set up an optical level and or plumbbob.
Re: 8' Level
« Reply #2 on: November 21, 2015, 08:13:12 PM »
piano wire was also used to check I-beams for any sagging.
Re: 8' Level
« Reply #3 on: November 22, 2015, 07:46:19 AM »
I had balloon framing stuck in my mind but I reckon it would have worked in lots of different ways, thanks.
Re: 8' Level
« Reply #4 on: November 22, 2015, 12:12:23 PM »
Along that same line, I know of 4 overhead cranes built in 1942 in a war plant that had stressed piano wire on the main beam for deflection indicators till the wire rotted.   Story was a few men beeded to change their underwear when the weight landed.
Offline mvwcnews
Re: 8' Level
« Reply #5 on: November 22, 2015, 01:07:40 PM »
Long levels for masonry & concrete flat work -- I have a 72" long level designed  for flat work -- the top edge is highest in the center, with a hand hold cut in -- the vial is centered below the hand hold & only viewable from the sides.
