Author Topic: A very heavy whats - it  (Read 11132 times)
Re: A very heavy whats - it
« Reply #15 on: October 08, 2015, 10:32:54 AM »
@40.8 lbs. per sqft 1" depth it would weigh 405 lbs, less the grooves and holes.
« Reply #16 on: October 08, 2015, 01:16:46 PM »
item overall is 22 long by 13 wide by 5 inches deep.
three round holes are 1 1/2, 1 inch and 3/4 in diameter and go all the way thru
the divots are 4 1/2 wide
one is 13 inches long  the other is 15 inches long
both are 1 inch deep at he lowest point
If you know the sagitta length and arc width (length of the chord) you can find the radius from the formula: where:
s is the length of the sagitta
r is the radius of the arc
l is one half of distance across the base of the arc (half the chord length)
r= s2 + i2
        2s
Based on your dimensions, the "Chord" of 15" & "Sagitta of 1" the radius should be 28.625" or ~ 57.25" dia.
13" & 1" sagitta= 21.625" R.  or ~43.25" Dia.
« Reply #17 on: October 08, 2015, 01:27:15 PM »
Twilight, that's a picture of what happens when a center of train assist locomotive that is radio controlled from the front end gets the wrong message.   The train was parked and the assist loco got the wrong idea in its computer.  That set of divots took a while to accomplish, and nobody noticed until they tried to move the train.
It's also a picture the railroad and loco manufacturer didn't want made public.  It proves what train crews have known for a long time, radio controlled chochoos ain't as safe as management claims.
« Reply #18 on: October 08, 2015, 03:32:41 PM »
It rings a bit, not like a good anvil, but not a thud either.
It might weigh more than I guessed, two people put it into the truck, but I suppose they could lift 150 pounds each, they were young
not hollow in back
