Author Topic: Interesting Old Steel Machinist Square ? ~ Unmarked Any Idea of Maker  (Read 2072 times)
Offline junk250
I'm Back  :grin:
Today's find,
Really interesting all steel "Machinist Square"  ?
The item is not marked with a maker mark that I can find.
It measures approx. 17" x 8", Extremely well made and has decorative diamond patterns(goes thru to both sides) that are made with alternating brass and copper pins.
It has a total of 33 dowels in it, 24 decorative brass/copper pins and another 9 steel pins holding the base together, 5 large pins in the corner, two in the middle and two more on the end.
It appears the base is made from 2 pieces of steel and pinned together(with 33 dowels).
The fitment is so accurate the pins are almost invisible.
There is a little slot through the base, whats that for ?
It is pretty heavy, all steel, weighs maybe 4 or 5 lbs.
Any information would be appreciated.
It looks pretty old to me, turn of the century maybe older .
Thanks for the Awesome forum !
Nice right ?
« Last Edit: August 05, 2015, 03:34:17 AM by junk250 »
Re: Interesting Old Steel Machinist Square ? ~ Unmarked Any Idea of Maker
« Reply #1 on: August 05, 2015, 08:34:47 AM »
Looks very nice. It seems to have a custom made look to it. Hard to make out the slot in the base, could it be to slide in another square to make parallel lines for some specific job ?
« Reply #2 on: August 05, 2015, 12:47:24 PM »
wasn't there another post that said it was for holding up on longer pieces by putting in the attachment
when needed ???
Offline Twilight Fenrir
« Reply #3 on: August 05, 2015, 01:07:30 PM »
I'm not 100%, but I believe I have a nearly identical, but smaller one in a big box of old tools I picked up a while ago... I'll go digging for it when I get a chance...
I think the slot would be used for an anlge finder to pass through it... But that's just speculation.
« Last Edit: August 05, 2015, 01:14:59 PM by Twilight Fenrir »
« Reply #4 on: August 05, 2015, 08:57:07 PM »
Twillight, If you dig out the one you have it would be interesting to know if it would fit into the slot on the one that junk250 has.
Offline leg17
« Reply #5 on: August 05, 2015, 10:10:57 PM »
when needed ???
I believe you are not mis-remembering.
Offline junk250
« Reply #6 on: August 06, 2015, 12:42:18 AM »
Thanks for the replies.
I know it's hard to tell much with the crappy pics, but I was exited to show it.
I'll try to get some better pics up soon showing more detail .
It seems like a manufacturer would have put a maker mark on it, whoever made it was very skilled I'll say that much.
Any guess on the age?
« Reply #7 on: August 06, 2015, 10:48:02 AM »
Nope, I was remembering wrong... I do have one with brass dowels, but the fat part is made of wood, and the pins run through this.... Goofy tri-lobal shaped thing... I'll have to take a picture... It's fancy, but not as fancy as the OPs
