Author Topic: flatten tapers drills  (Read 2700 times)
« on: July 13, 2015, 12:41:59 PM »
Found 2 brace type drills with unusual drive heads, flatten tapers.. doesn't look like it would fit into a regular brace (square taper)..  what type of tool is used to drive these drills?   anyone  know or seen these type of drills?
Offline PFSchaffner
    • VintageMachinery profile
Re: flatten tapers drills
« Reply #1 on: July 13, 2015, 03:52:59 PM »
I don't know but I have some too.
pfs
member: TATHS | MWTCA | EAIA | MVWC | CRAFTS
tool-cleaner and -sorter, Ann Arbor Kiwanis Thrift Sale
« Reply #2 on: July 15, 2015, 01:11:15 PM »
Closer look...  looks like they were hand ground, not factory machined..  why?
Offline PFSchaffner
« Reply #3 on: July 20, 2015, 08:59:20 AM »
I finally dug one out. It certainly *appears* to have been machine-made (i.e. not modified), but one never knows. For one thing, the broad surface has a stamped marking on one side (the other side has an off-center detent-style hole). The marking is difficult to make out, but says something like:
  PREUHER
    THIEL
"THIEL" is quite clear. The first word much less so. Indicating degrees of uncertainty with layers of parens, I'd transcribe as
PR(E)((U))(((H)))ER
This means nothing to me.
pfs
Offline PFSchaffner
« Reply #4 on: July 20, 2015, 09:05:54 AM »
and here's the 'detent' hole and the narrow edge:
pfs
« Reply #5 on: July 20, 2015, 01:22:09 PM »
I wonder if these were made not for a brace drill, but for a wooden  Tee handle drill?  Especially with the European sounding name, brace drills were not as common over there.
« Reply #6 on: July 20, 2015, 05:16:13 PM »
I was just thinking the same thing, but you posted while I was watching TV...
« Reply #7 on: July 23, 2015, 06:53:39 PM »
Thanks guys, makes sense..  hopefully someone knows for sure what they are...
« Reply #8 on: August 18, 2015, 06:58:16 PM »
Some braces didn't have adjustable collets, but they did have a wing nut or set screw.
My swag is a fixed collet that fit these ends.
Chilly.
