Author Topic: Broadax  (Read 1495 times)
Broadax
« on: July 07, 2015, 05:42:56 PM »
Is this a broadax or a side ax ? How broad does a broadax have to be to be a broadax ?
Re: Broadax
« Reply #1 on: July 07, 2015, 05:46:20 PM »
I have been lead to believe that a broad axe has a bevel on both sides of the blade.   A side axe or shaping axe has only one side beveled, plus one entire side is flat and will lay flat on a table.   Especially for shaping logs into beams.
Re: Broadax
« Reply #2 on: July 07, 2015, 07:37:55 PM »
Per Sellens the term broad axe and side axe can be interchanged but a side axe is usually a single handed axe and a broad axe is used with 2 hands. Many different blade/head patterns and different axes are shown in his book "Dictionary Of American Hand Tools"  under Axe pages 23 - 39.
Offline donald_wa
Re: Broadax
« Reply #3 on: July 07, 2015, 09:18:56 PM »
It is indeed a broad axe. They are fitted with a curved handle  (to protect your hands ) and that handle can be fitted from either end of the unusual poll.
Re: Broadax
« Reply #4 on: July 08, 2015, 12:01:52 PM »
Yes, side ax and broad ax are two names for the same thing -- an ax or hatchet ground on one side, like a chisel.  I believe that side ax is a more British term while broad ax is preferred in American English.  Salaman also illustrates a "wheelwright's ax which is sharpened in this manner.  For some reason, American English uses side ax for the cooper's tool, but broad ax for the larger tool used for hewing beams.
