Author Topic: 8" HackSaw Blades  (Read 2865 times)
Offline leg17
8" HackSaw Blades
« on: June 19, 2015, 11:49:25 AM »
Sorry if this has come up before.
Does anyone know where I might purchase 8" long hack saw blades?
Are they gone the way of buggy whips?
Offline JUNK-MAN
Re: 8" HackSaw Blades
« Reply #1 on: June 19, 2015, 11:58:35 AM »
I have never seen one but you could try googling it and see were that takes you.
« Reply #2 on: June 19, 2015, 02:46:38 PM »
try ebay, there are a few there right now.
 try;    8 inch hacksaw blades
« Last Edit: June 19, 2015, 07:49:48 PM by turnnut »
Offline leg17
« Reply #3 on: June 19, 2015, 07:08:40 PM »
My bad!  Should have been more clear.
Looking for conventional hand hacksaw blades for antique hack saw that is 8" long.
Thanks all for suggestions.
« Reply #4 on: June 20, 2015, 01:56:35 PM »
I'm confused; how long do the blades need to be?  Pictures of your hacksaw might help.
Offline leg17
« Reply #5 on: June 20, 2015, 07:05:47 PM »
Blades need to be 8 inches long.
Here is a picture of a saw that won't accept 10" or 12" blades.  Only 8".
ebay lot no.     371329278582
Thanks all.
Offline Analog
« Reply #6 on: June 20, 2015, 09:20:25 PM »
I encountered the same problem a few years ago and wound up making my own.  Cut a 10" or larger blade to desired length using tin snips, Use the cut off piece as a template for the mounting hole and to replicate the shape of the original end. Use a grinder to form, then drill the mounting hole.
Offline leg17
« Reply #7 on: June 21, 2015, 05:35:27 AM »
Analog
That's what I guess I will do.
Just trying the easy route first.
Thanks
« Reply #8 on: June 22, 2015, 10:25:27 AM »
Analog
Thanks
I do this all the time.  It's extremely easy!  A 12 inch blade makes one for my 8 inch hacksaw and another for my 4 incher.  Scraps left over from making blades for my 6 inch hack saw make blades for scratch stock or work as scrapers.
« Reply #9 on: June 26, 2015, 10:05:44 PM »
If you want to go first cabin on this, get yourself a Whitney Jr. punch http://www.roperwhitney.com/portable-light-duty.html
It'll make the holes for the pins in the hacksaw frame better than drilling.
You'll notice that I'm giving you an excuse to buy another tool.  No, no need to thank me; happy to provide the service.
« Reply #10 on: June 27, 2015, 12:52:10 AM »
Broken hacksaw blades make excellent lock picks, just need to grind them to the various shapes.
also makes good scrapers.. Exacto type specialty knifes, etc..
« Last Edit: June 27, 2015, 01:05:41 AM by oldtools »
Offline leg17
« Reply #11 on: June 27, 2015, 07:41:21 AM »
Thanks.  That's what friends are for.
