Author Topic: stanley no. 81-050 honing guide  (Read 9883 times)
Offline amertrac
  • ny mountain man
« on: September 22, 2011, 06:09:23 AM »
Found this in the depths of oblivian under me desk. checked out on internet that it has been discontinued . woodworkers would not buy them? they did not work well ? replaced by newer product?  inquring mind wants to know.  bob w.
Re: stanley no. 81-050 honing guide
« Reply #1 on: September 22, 2011, 07:10:42 PM »
They have been waiting 30 years for you to send back the customer satisfaction survey card so they would know if it was a good product or not.....
The (very) few folks that I know of that actully bother to sharpen irons seem to all think the guides are silly if you know how to do it by hand with a plain old stone and some spit....
So...I suppose marketing at Stanley finally tripped over the precipice on that one..
« Reply #2 on: September 22, 2011, 08:59:06 PM »
Stanley had other models as well.   I bought one 30 odd years ago because it looked like the very thing.  I used it about twice.  The style you seem to have is still manufactured, but if you really want to get all CDO about it, you can spend $109.99 at:
http://www.woodcraft.com/Product/2020080/19122/Pinnacle-Honing-Guide.aspx?refcode=10INBING
Scrolling down the page shows a couple of other designs, one like the version I bought all those years ago.  Me, I do it with water or oil, depending on the stone, and by hand.  Mind you, I'm not as fussy as some folks, but i do pretty good.
« Reply #3 on: September 22, 2011, 10:14:41 PM »
What, you didn't also get the granite surface plate so you can measure how many iron atoms remain to be ground off? LOL
That is quite a gadget tho, they seem to have incorporated every possible feature into it...
If you can't sharpen an iron with that thing, it is time to seriously consider a new career as a balloon inflator....
« Last Edit: September 22, 2011, 10:16:29 PM by rusty »
« Reply #4 on: September 23, 2011, 11:41:15 AM »
It was on the market too soon!
 It came and went before the fad came on.
  Nowdays, there are a legion of guys are using elaborate jigs and expensive stones and equipment and polishing blades out to 20,000 grit. Rubbing and rubbing they spend hours on a single blade.
Most of them don't really cut any wood, or if they do its mostly for test purposes.
 I know a guy who mirror polishes blades out to the atom, and then photographs the edges with a microscopic camera and then tests the edges to the tune of 4 or 5 hundred full length shavings (from a 6" plank)
  to rephotograph and record the edge retention/degradation.
 One time he asked me, "Can your edges do this?"
   I answered, "I don't know. I spend about 2 minutes resharpening a plane blade and if I had to make 4 hundred test cuts I'd kill myself.
 Its has become a national obsession. Its an entire hobby of sharpening steel.
So many newbies and wanna-be's are insecure about their ability to sharpen a simple edge tool,  that sharpening equipment has eclipsed all other woodworking tool sales.
 And its growing. Guy are paying hundreds of dollars for a single sharpening stone. The Japanese are catering to this insecurity and the Yuppie-puppy syndrome of one upsmanship in price, with "designer" label goods and 10 times the asking price.
  Me, I make things from wood.   I make tools themselves, and I make other things.
 I can get a comfortable shave from any edge tool in 2 minutes or less time, and its a plenty good enough edge to let me work in the hardest woods.
 But then, I was already working wood before much of the current crop was born or certainly ever know what a plane was.
 I had a jig almost just like the Stanley shown, once.
  I used it when I was first starting, in the 60's.  It worked, but it took too long.
 I started sharpening freehand, got better at it, and never went back.
« Reply #5 on: September 23, 2011, 07:07:51 PM »
Sure case of CDO.  Precision obsession variety.  I knew a hobbiest blacksmith who kept a magnet to test for proper welding temp.  For a lot of them it's all about the mystique.  For the old pharts, it was about earning a living, and working fast enough to make money.  The time spent in producing micron edges ... well, the old pharts would have spent that time making things and a living.
« Reply #6 on: September 24, 2011, 02:44:49 PM »
Here is one of the floor sweepings when I was making the baby bed.
Freehand honed edges aren't so bad..........
Offline Jim C.
« Reply #7 on: September 24, 2011, 07:52:08 PM »
I never tried one of those sharpening jigs.  I suppose they'd work okay.  I usually just sharpen plane irons and chisels free hand.  I do most of my sharpening on a slab of scrap granite.  The granite came from a kitchen sink cut-out.  With some spray adhesive, I glue down a few different grits of sandpaper to the granite.  Then, starting from about 220 grit and finishing at 2000 grit, with a little water for lubricant, I can get a pretty good edge.  If I'm starting with a relatively straight edge, the whole process takes about five to ten minutes.  Simple honing takes a little less once I've got the edge profile and bevel the way I want it.   If I get a plane with a really bad iron, I usually just start from scratch and re-shape the profile and bevel on a slow speed grinder.
Jim C.
Our Go-To Type Study Member
« Reply #8 on: September 24, 2011, 08:36:41 PM »
As odd as it may seem..... I spent some time in this profession
Worse yet, I did it dressed as a bear.
might explain my peculiar collecting habits.
Skip
