Author Topic: Forgot I had this stashed  (Read 3291 times)
« on: June 03, 2015, 10:57:03 PM »
Now I gotta wonder if the Department of War will come after me for having it.
Honest, I pulled it off a pile headed for the scrapper 20 years back.
Pretty sure it needs new leads too.
Online skipskip
Re: Forgot I had this stashed
« Reply #1 on: June 04, 2015, 09:29:09 AM »
It's a welder??
« Reply #2 on: June 04, 2015, 12:07:57 PM »
Not a welder, very similar power unit but much lower amperage.
It's an electric Arc engraver.  This machine is still made with an electronic power unit, which has a use life of a few years, this oldie is still going and has to be early World War II vintage.  Hopefully I can find more information on it on the WWW.
« Reply #3 on: June 04, 2015, 02:01:46 PM »
 :embarrassed:
Looks dangerous to me.
« Reply #4 on: June 04, 2015, 04:35:30 PM »
WOW!! Now you too can screw up collector tools for future owners. Seriously, nifty score.
« Reply #5 on: June 04, 2015, 10:04:27 PM »
I'll make you the same offer I make everybody when it comes to marking tools.
You replace mine that grow legs and walk off, and I won't mark my tools.
Mine were born to work, not sit around and look pretty.
Offline JoeCB
« Reply #6 on: June 06, 2015, 02:10:56 PM »
I too have a similar old school arc engraver. I don't have much need for engraving things, However I have used it as a mini EDM to disintegrate small broken off taps. It works, a little slow but saved the day.
Joe B
« Reply #7 on: June 07, 2015, 02:24:46 AM »
Joe B
Joe that idea fascinates me.  I did have some experience years back with a machine called a Tap Disintigrator that used a vibrating hollow copper electrode with kerosene flowing through it to eat taps in their hole, and have considered using a TIG machine to attempt the same task.
The engraver power supply may be closer to the power unit on the Disintigrator, low voltage and high amperage.
I  did a little quick Amprobe testing today and found the engraver will produce over 200 amps at less than 2 volts running full out.
What do you use as an electrode to destroy taps?  Are you running any flush/cooling liquid?
Offline JoeCB
« Reply #8 on: June 08, 2015, 03:33:58 PM »
I used a piece of TIG tungsten rod. But I suppose that just about anything would work. Now, understand that I'm dealing with small taps, #6 - # 8. If you have a broken 3/4 - 10 stuck in a solid block... lot's of luck.
Joe B
« Reply #9 on: June 08, 2015, 10:29:20 PM »
3/4 would be a walk in the park, plenty of room to weld it out.  Taps shrink a lot when you run a pass down the flute, same system we use for removing sleeves from Diesels, compressors and valves.
I'm currently thinking the power unit is very similar to the old Weller 300 watt soldering gun, all kinds of amperage with low voltage.
