Author Topic: Big Chain  (Read 2355 times)
Big Chain
« on: May 23, 2015, 05:29:18 PM »
What do reckon this was used for? The links are 4 1/2" long and there are 15 of them.
Don't know why I brought it home but I had to have it.
Offline JUNK-MAN
Re: Big Chain
« Reply #1 on: May 23, 2015, 06:42:40 PM »
Did you ask the seller? It is probably for an industrial purpose on a crane for lifting large steel or concrete blocks or something in those lines.
Re: Big Chain
« Reply #2 on: May 23, 2015, 09:30:25 PM »
That chain looks to be what is know as " Long Link " in the Pulp mill and sawmill industry. The standard these days is 3/4" dia x 5"  or 1' dia x 6" long. It's typical use is for conveyors moving sawdust, bark or chips. They normally have a "flight" which consists of 2 pieces of flatbar 3/4' x 3' x 24" or so long welded into the links and spaced about 5' or so apart. Your chunk of chain looks to be a slightly smaller version of this type of chain and my guess is somebody rigged it up to use as a tow chin of some sort.
Re: Big Chain
« Reply #3 on: May 23, 2015, 09:38:37 PM »
are those links 1/2" diameter ?
Offline anglesmith
Re: Big Chain
« Reply #4 on: May 24, 2015, 03:50:11 AM »
Lot less and easier work hand forging ( fire welding) large link chain than making 3 times as many smaller links !? Note the hook had to be on the link be fore it was "shut" , which in my mind makes it unlikely to be commercial bought chain.  I think this piece of chain would date back to before 1900 and was probably made by a farmer out of what he had lying around?
Graeme
« Last Edit: May 24, 2015, 03:54:03 AM by anglesmith »
Offline anglesmith
Re: Big Chain
« Reply #5 on: May 24, 2015, 04:05:13 AM »
Second thought ! All the farm / workshop blacksmithing books from the early 1900s to 1950s  (J M Drew, Mack M Jones etc ) showed how to make this type of large link chain and basic hook.
Graeme
Re: Big Chain
« Reply #6 on: May 24, 2015, 07:27:40 AM »
Yes, and a few of the links have a stretched look to them.
Almost like they had one hell of a load on them.
Re: Big Chain
« Reply #7 on: May 24, 2015, 08:35:10 AM »
I've got a similar chain that's got an oval ring on the other end so you can use it as a choker. I use it to pull bushes and stumps out. The chain looks to be hand made and it 3 1/2" x 1 1/2" and 3/8 thick. I've tried to part with it several times and can't, It's too handy.
bill
