Author Topic: John Warren Watson  (Read 2316 times)
John Warren Watson
« on: May 10, 2015, 07:13:31 PM »
This was totally rusted when I found it all I could see is that there were letters on it.
http://www.classicandexotic.com/manuals/Watson_Stabilator_Manual.pdf
Re: John Warren Watson
« Reply #1 on: May 11, 2015, 12:08:27 AM »
Check the wrench end carefully.  The several I've seen over the years had a hex box end rather than open end -- so see if that one shows any signs of having been cut & ground off
« Reply #2 on: May 11, 2015, 06:18:53 AM »
You're correct, just checked and it has been clearly cut off.
Wasn't even ground down to try to smooth out the cut lines.
Still pretty cool.
Thank you.
