Author Topic: 3/4" Drive Plomb  (Read 2794 times)
Offline stanley62
3/4" Drive Plomb
« on: September 18, 2011, 08:17:59 PM »
Found this big boy a couple weeks ago.  I have just been a little behind in sharing (or gloating as the case may be).
Its a plomb  3/4" drive (5649).
Re: 3/4" Drive Plomb
« Reply #1 on: September 18, 2011, 09:50:13 PM »
I just picked up the same on off of CL about 3 weeks ago. The drive plug on mine was made by P&C a Plomb owned company starting in 1941. Mine has the wrong screws holding it together, but I have the correct ones to restore it. The former owner used straight slotted screws. He did use ones with the correct thread pitch,  so no side cover damage. I also have the 1/2 inch one. Now I need to get the 1/4 inch one.
« Reply #2 on: September 19, 2011, 05:14:25 PM »
Does yours have a removable drive plug ? If it does, you might check to see if it is marked with the makers name.
Offline stanley62
« Reply #3 on: September 19, 2011, 08:12:38 PM »
The plug is removable, I'll check when I get home to see if there is a makers name.  I didn't notice one when I cleaned the ratchet up, but I wasn't really looking for one.  I assumed that it was just part of the ratchet and wouldn't have any markings.
« Reply #4 on: September 20, 2011, 08:39:16 AM »
Sometime back I had another Plomb 3/4 drive ratchet that also had a removable drive plug. It was a pebble field style ratchet. I don't remember if it had a plug that was marked with a makers name. I am going to keep this one.
Offline stanley62
« Reply #5 on: September 20, 2011, 01:39:02 PM »
I checked the plug.  No markings of any kind.
