Author Topic: Input wanted....cleaning plated tools such as sockets...  (Read 6614 times)
« on: January 14, 2015, 12:13:40 PM »
How does everyone clean up sockets that are plated? I have probably 60 or so odds and ends sockets in various states of grunge.
Has anyone tried a tumbler or vibratory tumbler like those used for shell casings when reloading ammo?
I really don't have much time to clean each one by hand, and input on alternative methods of cleaning a large number of them would be helpful.
Thanks.
Re: Input wanted....cleaning plated tools such as sockets...
« Reply #1 on: January 14, 2015, 01:17:44 PM »
Aaron, I've never cleaned more than a few at a time.  Steel wool or a soft wire wheel outside.  Valve guide brushes for small sockets and one of those plumbing round wire brushes they use to brush copper fittings before welding.  I cut the handle part off and stick in a drill motor.
« Reply #2 on: January 14, 2015, 01:41:51 PM »
I have chucked a socket onto an extension then turn it into a soft wire brush, also spun it against a 3-M pad.
« Reply #3 on: January 14, 2015, 05:23:48 PM »
When i was still working, i had the use of a glass bead blaster and used it to do the insides of sockets. The outside i did with a cut off socket extension chucked in a drill press and a green scratchy pad used to wash frying pans. I also had the use of a Storm Vulcan parts washer for engine parts. I would string the sockets together with wire and wash the grease and dirt off of them before derusting / polishing.
« Reply #4 on: January 14, 2015, 10:17:40 PM »
Some great ideas, fellas!
I have a bunch of plated sockets, all different drive sizes from 1/4 to 1/2 that I need to get cleaned up.
One bunch in particular is several Snap-On sockets that have some surface rust on them. They look to be nice vintage ones, the sliding T Bar is marked with the Ferret marking.
I know a brass wire wheel works great, but I can't seem to find an actual Brass one. All the ones I see are steel, plated in brass. That leaves me with only brass hand brushes to work with. That gets old real quick, in my opinion.
I think I may get a cheap vibratory tumbler from Haba Flate and give it a try with whatever media I can find to work on plated things. I can always use it for other brass parts from my Coleman lantern addiction.
« Reply #5 on: January 15, 2015, 03:08:28 AM »
Ile do it for you, just send them my way. Just don't expect to receive them back. LOL
It's not fast but the way I do my sockets is just use a bench grinder an some wd40 or evapao rust. I use a real stuff buffing wheel to get the grime off an light rust. To hold it to the wheel I use a cheapo extension with vise grips at one end an socket at other.
I would be interested to hear how your horrible frieght parts tumbler goes. Keep us posted.
« Reply #6 on: January 15, 2015, 07:40:17 PM »
I know what you mean about the phony brass wire wheels. I went and bought a Bosch brand one and it was steel with brass plating. The package even said brass wire wheel. Big time ripoff. I'm calling my lawyer. Class action lawsuit time.
XXXXXX
« Reply #7 on: January 15, 2015, 07:50:57 PM »
I met a guy that used an old wringer/washer with fine playground sand to clean rusty wrenches.
soda grit might work on chrome tools.
check with Eastwoods for diff. kinds of grit.
just a thought.
Offline lauver
  • Belton, TX
« Reply #8 on: January 15, 2015, 10:09:56 PM »
keykeeper,
I like your idea of a vibratory tumbler with dry crushed walnut shell or similar for cleaning sockets... it's at least worth a try... and can't hurt anything.
I would suggest degreasing the sockets first with solvent and then drying them out before the tumbler treatment.
Let us know how it works out.
« Reply #9 on: January 15, 2015, 11:57:52 PM »
Go to the Dollar store and get a few of the 3 packs of wire brushes that have a brass, a stainless and a fiber brush.
Find a crock pot, definitely not the one your wife or girlfriend loves, and put the sockets in it with a solution of Simple Green and water.  Cook for 24 hours at around 180°.  Pull HOT sockets out 1 at a time with pliers and brush crap loose under running water.
Don't want to go that way, soak em in Diesl fuel for a few days.
If they're rusty soak them in molasses for a few weeks, in a warm place.  If the chrome is compromised you can brush it till the cows come home, it will still rust.
Offline humber2
« Reply #10 on: January 16, 2015, 01:05:29 AM »
Hard to clean areas are in and around lettering followed by inside in the splines.
Using solvent or paint stripper followed by a wash and scrub in a strong hot water detergent gets a new look at  them.
The strong detergent seems to put a cheap rust preventor back on them.
Often followed by Evaporust and another wash.
I wouldn't go the tumble or other abrasive methods.
« Reply #11 on: January 16, 2015, 02:13:08 AM »
I have a lot of tumblers.  All the way up to a medium floor standing model. Big brass barrel, probably weighs 40 lbs.  Most have 1-1/2 to 2 gallon barrels.
Walnut shells often come with rouge. Works well polishing brass, like shell casings.  For cleaning I would use plastic pellets with soap. For rust removal I would go for media softer than the sockets, but harder than the rust. Maybe stainless steel media with vinegar.
I use srainless steel media to burnish sterling silver. Shines it right up, and work hardens it too.
Vibratory mass finishers are often more aggressive than barrel types.
Offline burnsie
« Reply #12 on: January 18, 2015, 11:19:32 AM »
XXXXXX
A real brass wire wheel will cost you. I paid almost $50 for mine on Zoro. I would just assume any wheel less than $30 or $40 is not going to have solid brass wires.
Offline burnsie
« Reply #13 on: January 18, 2015, 11:29:35 AM »
Thanks.
I clean almost every used tool and storage piece I buy with TSP (the real stuff) and hot water.
I fill up my laundry tub (it's in the basement) with a hot water and TSP solution and use a brush to clean them en masse.
Anything with rust, whether minor or major, goes into a container of diluted vinegar* for one day or more. Except for saw blades as the etchings are vulnerable to the vinegar solution.
*I've been using the same 5 Gal Rubbermaid container half full of vinegar solution for a couple years.  I've never changed it completely but amend as needed.
Offline OkieTools
« Reply #14 on: January 19, 2015, 09:19:31 AM »
I've used Evapo-rust from HF on hundreds of tools, that stuff works good. I put them in a plastic container, and let them sit for anywhere from one day all the way up to a week some times. Depending on how much rust is on there. Then get them out get anything that mite still be on them off with a wire brush, you don't have to work to hard on it, it just comes off thanks to the Evapo-rust. Then go wash them in hot water with a degreaser soap, dry them good, then I put a little preserving oil on them, to keep them from rusting again, then wipe them dry and put them back in the box.
I also recently tried CLR it works to, just keep your eye on it, and use a good container for it, don't leave your tools in for more than two hours. Then get them out, and go through the same steps as above to wash them off.
Good luck.
Vintage tools have a story to tell, and I want to hear it.
