Author Topic: What is it??  (Read 8083 times)
Offline blackoak
What is it??
« on: January 08, 2015, 11:49:51 PM »
Had these for several years and never could tell what they were used or designed for.
« Last Edit: January 16, 2015, 11:52:27 PM by blackoak »
Re: What is it??
« Reply #1 on: January 09, 2015, 12:51:20 PM »
Kitchen tool? Combination utility shears and bottle openers?
Re: What is it??
« Reply #2 on: January 10, 2015, 12:54:28 AM »
I've seen examples before -- no markings, and the sizes of the openings are too small for most kitchen applications.  An unsolved mystery at this point.
Offline crankshaftdan II
Re: What is it??
« Reply #3 on: January 10, 2015, 06:48:32 AM »
Kitchen shears-bottle opener-canning jar ring crimper/opener--Just a WAG!
Re: What is it??
« Reply #4 on: January 10, 2015, 01:48:09 PM »
Here's my wag - those look like they would fit several types of small shut-off valves.  Doesn't explain the scissors though....,
Re: What is it??
« Reply #5 on: January 10, 2015, 03:01:08 PM »
Snips for cutting off "Lock out-Tag out" tags?
Re: What is it??
« Reply #6 on: January 10, 2015, 05:01:04 PM »
I like it!
Online Lewill2
Re: What is it??
« Reply #7 on: January 10, 2015, 05:51:30 PM »
Lockout tag out tags should be put in place with locks so only the person working on the equipment is able to remove it with their key. You shouldn't use wire ties or other devices.
Trailer security seals maybe but these pliers don't look heavy duty enough to cut the metal ones, maybe the plastic ones.
My 2 cents
Offline blackoak
Re: What is it??
« Reply #8 on: January 10, 2015, 06:04:32 PM »
I tried to use it to open one of my favorite beverages and although it will open a Miller Lite beer bottle, it was hard to use it that way. The prongs are spaced to far apart to get leverage to pry the cap off.
Re: What is it??
« Reply #9 on: January 10, 2015, 07:00:05 PM »
I don't think those snips would work on any lockout scissors or padlocks that we use up here in Northern British Columbia. I ran a construction company for many years and had  to cut locks off a time or two and we usually used a big bolt cutters or a zip cut. Generally happened when an employee went home and forgot to take his lock off, our procedure was we had to contact the person by phone or whatever before cutting the lock or scissors. Proved very costly in some cases, but you had to make sure the person was not on the job site. I think chilly maybe be onto some thing with his take on it. When the you close them up does the clamp closest to the jaws form a ribbed concentric circle on the inner and a hex on the outer ? How long is this guy overall and how long are the jaws of the snips?
Re: What is it??
« Reply #10 on: January 10, 2015, 07:24:48 PM »
rereading Chilly's reply, if it was for valves, the scissors could be use to cut off any
out of order tags.
these could have been used before OSHA's mandates.
just a thought.
Re: What is it??
« Reply #11 on: January 10, 2015, 07:33:25 PM »
Holding out for lockout tags-
« Last Edit: January 10, 2015, 07:35:05 PM by Papaw »
Re: What is it??
« Reply #12 on: January 10, 2015, 08:23:48 PM »
good find Papaw,
and string was also used. easy cut.
Re: What is it??
« Reply #13 on: January 10, 2015, 10:07:40 PM »
Still don't know if the other part will turn valves or such.
Offline geneg
Re: What is it??
« Reply #14 on: January 11, 2015, 11:06:32 AM »
Hard to tell without a scale for size reference, but the serrated opening could be for the stem of a boiler drain or valve, the other opening for a specific jamb nut on the same, & the cutters for the graphite impregnated cord that was used for packing material.
