Author Topic: Recent scores from free bulk pick-up..  (Read 2299 times)
« on: December 19, 2014, 04:36:29 PM »
 :grin:  Recent scores from free bulk pick-up.. several screwdrivers, pliers, etc. old files, and 1/2" & 2" trowels..  a 11" chisel 1 1/4" wide, bent to be flat on surface.. 1/2" japan breaker, Old 1/2" DuraChrome ratchet Pat. no. 1902878, a plastic hinged piece with brass threaded hand screws?? and a Jorgensen miter saw #64027, also 24" long tile cutter, box full of painting tools, scrapers, sanders, rollers, etc. & concrete tools float, trowels, etc. also a hand pump sprayer.  very happy I was in the right place at the right time, they would have been gone if someone else seen this..  Don't know if I can show all photos..
« Last Edit: December 20, 2014, 01:48:28 PM by oldtools »
Re: Recent scores from free bulk pick-up..
« Reply #1 on: December 19, 2014, 05:00:03 PM »
Another save! Good for you!
Loving that 1/2" Duro rat. Here's it's two smaller siblings.
« Reply #2 on: December 19, 2014, 05:10:28 PM »
Thanks Bonnyman, same pat# but all different? mine is 1/2" male & female drive.. is 1902 the year? 878 pat#...
« Reply #3 on: December 19, 2014, 05:16:35 PM »
Heck of a miter saw - look at the size of the blade!  What is the thing in the 4th photo?
« Reply #4 on: December 19, 2014, 08:48:19 PM »
Mine didn't come with the plugs. Sealed mechanism, but cleanable thru the oil hole with JAFE juice then let drip dry and add some oil.
« Reply #5 on: December 19, 2014, 11:13:47 PM »
You
Great finds.
« Reply #6 on: December 20, 2014, 01:23:27 AM »
Jorgensen Hand Operated Miter Saw 14" Wide base, 24" Blade 1 - 3/4" wide..  Cuts fast!!
Don't know what it is, hope someone can ID it.. doesn't open more than 90 deg. closes flat..
« Reply #7 on: December 20, 2014, 02:03:04 AM »
more photos..
24" tile cutter & 2 SS bath hand rails..
Box of painting tools, hand sprayer & concrete tools..
also found 2 spools of 10 gage THHN wire. 500' each.. had to tie rope to handle the weight..
must be year end cleaning time of someone's stuff, by someone who doesn't know the value..
Someone's trash is my treasure..
« Reply #8 on: December 20, 2014, 10:38:48 AM »
Yep. I found an old (1988) Panasonic microwave with GLASS rotating plate in the alley, thrown out. Took it apart, and all I found was the door switch was stuck "on" due to years of grease and gunk. Replaced the switch, gave it a good cleaning, and it's now my back-up micro for the house. I'm surprised the glass plate has survived intact.
Just amazing what folks throw away!
