“You can use an eraser on the drafting table or a sledgehammer on the construction site.” - Frank Lloyd Wright
Used to find quite a few of them in heavy truck spring shops for tightening down U bolts.Smarter shops set them up on a pair of roller skate wheels so the mechainc didn't need to lift and hold the wrench.That little darling will hurt you if the trigger sticks.It doesn't hammer, because it doesn't need to hammer.It will also hurt like hell if dropped on your toe.3/4 air line minimum.
