Irwin 900?
Started by dimwittedmoose51, September 05, 2011, 11:50:40 AM
dimwittedmoose51
So here's a 6" long wooden-handled tool with a spiral thread on the end of it.  Anyone know what it's designed to do?  It says Irwin  900  USA on the shaft.
TIA
DM&FS
Champion Pawn/Flea Plunderer
lzenglish
According to our Good Buddy "wvtools", it is a screw starter, as he has one for sale on ebay. I had never seen one like it before myself. It must be designed for pre-threading screws in hardwood, or furniture, etc?
Wayne
Neals
kxxr
I have a modern black and yellow handled Stanley just like it, smaller tip though. Just used it yesterday. It is handy for starting a hole if you don't have far to go and you don't want to break out the drill.
Quote from: lzenglish on September 05, 2011, 12:26:08 PM
Wayne
Not a screw starter.  It drills a conical hole for inserting a wood cone so that a screw can hold in an enlarged hole.  Plugs the hole.
lzenglish
#5
Quote from: Branson on September 05, 2011, 08:01:35 PM
So If I read you correct, you are saying this if for repairing an enlarged, or stripped out screw hole in a door Jam hinge hole, or other wood material Correct?
Wayne
Quote from: lzenglish on September 05, 2011, 09:03:37 PM
Wayne
Exactly.  I saw them advertiser, oh, maybe 20 years ago.  Thought it was a neat idea, but never got around to getting one.  They came with the conical plugs to insert.
ToolsorDie
Wayne
I always use wooden matchsticks to tighten up the screw hole, too cheap to buy a fancy tool for that simple job, yes I have hillbilly tendencies. Might be thee reason they never caught on to well.
I always use wooden matchsticks to tighten up the screw hole, too cheap to buy a fancy tool for that simple job, yes I have hillbilly tendencies. Might be thee reason they never caught on to well..
[/quote]
Me, I use toothpicks.  Maybe between the two of us we sent the company into oblivion.
ToolsorDie
[/quote]
[/quote]
I would like to take credit with you for doing that but I think common sense killed that tool idea.
Neals
Toothpicks, match sticks, golf tees depending on the size needed works for me.
Hadn't thought of golf tees.  Now I will!  Thanks.
ToolsorDie
Quote from: Branson on September 07, 2011, 07:17:31 PM
And if those don't get the job done, I whip out my Tuboencabulator
http://www.youtube.com/watch?v=rLDgQg6bq7o
Papaw
QuoteTuboencabulator
I remember that from somewhere.
1930
Weed wacker string works best in my opinion because it gives put also pushes back, wont go away either eventually.
