Author Topic: Couple of oldies  (Read 4485 times)
Offline Flatland Dave
Couple of oldies
« on: November 02, 2014, 09:08:36 AM »
Picked these up at an auction a while back.  The first of two estate sales of a guy who by all accounts loved Model T's and had a very keen eye for cool stuff.
I suspect the first is a battery carrier, for a small battery.
WP_20141101_001 by 57348, on Flickr
WP_20141101_002 by 57348, on Flickr
The other is self explanatory.
WP_20141101_003 by 57348, on Flickr
WP_20141101_005 by 57348, on Flickr
Re: Couple of oldies
« Reply #1 on: November 02, 2014, 02:09:59 PM »
it looks like you could carry a battery, are the clamps offset ?
any name on it ?   it's interesting.
 I would think that the frame would get mighty warm.
 if your hand slipped off of the wood handle,  ouch !
 just my opinion.
« Reply #2 on: November 02, 2014, 02:54:06 PM »
Never thought about that.   Dang so much for that theory.
Clamps are independent.  Basically shovel on the bolt thru the handle.
Offline Charles Garrett
« Reply #3 on: November 02, 2014, 03:46:15 PM »
The carrier is for a 6 volt attery and the load tester was when the cells had external connecting straps. I had a pair of pliers with hinged loops on the ends of the handles for a battery carrier.  That would sure be a hot one to use unless the battery was totally dead.
« Reply #4 on: November 02, 2014, 06:35:34 PM »
That's what I was thinking. Being all metal, and it looks like the clamps grab the posts, the battery should be pretty much dead or you're going to get a spark.
« Reply #5 on: November 02, 2014, 07:52:22 PM »
Thanks for the info.  That could be handy here as a hand warmer tho....
Offline JoeCB
« Reply #6 on: November 02, 2014, 09:31:38 PM »
Is there continuity thru the wood handle, I'll bet not!... The design most likely is two separate studs rather than what appears to be a thru bolt or rivet.
Joe
« Reply #7 on: November 03, 2014, 05:36:51 AM »
Wooden handle spins freely on the rod that goes through the middle.  I'll try to get better pics this evening.
« Reply #8 on: November 03, 2014, 10:20:39 AM »
Looks like bolt is not original.
« Reply #9 on: November 03, 2014, 01:41:37 PM »
I believe that the bolt went straight thru the handle, otherwise, you would have too much
flex on the two pieces.  the wood handle would have been safe if you did not slip your
grip sideways and touch the metal.
more than likely from the 20's way before "OSHA" became our watch dog.
work, home or play, cell phones are a big reason for accidents.
