Author Topic: Perfect Handle Screwdriver 660 Sizes  (Read 18357 times)
Re: Perfect Handle Screwdriver 660 Sizes
« Reply #15 on: March 10, 2015, 10:57:42 PM »
You are in the right place!
LOOK!!---> http://www.papawswrench.com/vboard/index.php?topic=728.0
Offline Gunpilot
« Reply #16 on: March 11, 2015, 08:51:06 PM »
Thanks,
I need to clean a few of mine up and post a picture or two.
« Reply #17 on: March 13, 2015, 12:30:46 PM »
What are your thoughts on modifying these by adding modern tips or tool heads?  My goal is to restore or preserve the better examples that I have, but for damaged or redundant tools, I plan to modify a few for work bench use.
Greg
Yeah, you've come to the right place.  Scott G has turned some run down PH tools into useful things of beauty!
Offline Yodaslo
« Reply #18 on: January 27, 2017, 10:26:41 AM »
Hello,
I have been collecting the tools in the HD Smith & Co Catalog No. 25, printed in 1920, for 12 years now.
(I have a reprinted catalog you see now and again on Ebay, not an original catalog.)
I believe someone had asked if they really made all they tools in their catalog.
I believe they did. Iffy on their #2 and #2-1/2 sizes on a couple of their screwdrivers.
It's been 12 years of serious collecting now, and I haven't seen them yet.
Anyway, in addition to the other tools listed in their #25 catalog (I'm only missing a few now!),
the discussion was on their lines of screwdrivers, so here goes:
In the New Improved "Six-Sixty" (#660) Screwdrivers (CIRCLE S on the shaft), I have the :
#3
#4
#5
#6
#7
#8
#10
#12
(Not really sure if they made a #2 or #2-1/2)
In the Original "Six-Sixty" Winged (#660) Screwdrivers (WINGED cross hatching on the handle), I have the :
#3
#4
#5
#6
#7
#8
#10
(I am sure they made a winged #12, just haven't seen it yet)
(Not really sure if they made a #2 or #2-1//2)
(They also made another "Six Sixty" Winged (#660) with smooth wings (no cross hatching). I assume to reduce cost.
In the Regular Screwdrivers #609 (no size stamp on the tip), I have the :
#2
#3
#4
#5
#6
#7
#8
#10
#12
(Not really sure if they made a #2-1//2)
In the Regular Screwdrivers #609 (WITH size stamp on the tip), I have the :
#2
#3
#4
#5
#6
#7
#8
#10
#12
In the Machinist Screwdrivers #610 (Square shafts), I have the :
# 9-1/2
# 10-1/2
(They only offered 2 sizes in their catalog)
In the Tobrin #30 Regular Screwdrivers, (Tobrin bought out the screwdriver line from HD Smith Co when HD Smith Co closed down), I have the :
#2
#3
#4
#5
#6
#7
#8
#10
#12
(Tobrin does not list the #2-1/2 as being made in their catalog)
Tobrin #30 screwdrivers look the same as HD Smith #30 screwdrivers, except for the Tobrin logo.
In the Tobrin #31 Machinist Screwdrivers (Square shafts), I have the :
#7-1/2
#8-1/2
#9-1/2
#10-1/2
(They offered 4 sizes in their #30 catalog/pamphlet)
Tobrin #31 screwdrivers look the same as HD Smith #30 screwdrivers, except for the Tobrin logo.
Hope this helps the original poster or any others.
Thanks
Rich
« Last Edit: May 07, 2023, 07:31:44 PM by Yodaslo »
« Reply #19 on: January 27, 2017, 11:12:09 AM »
How about a picture or two of the Tobrin no. 30 and 31. I'm not familiar with them.
« Last Edit: January 27, 2017, 03:31:17 PM by mikeswrenches »
Offline leg17
« Reply #20 on: January 27, 2017, 02:16:02 PM »
Thanks Smokey
I recently saw a 9 sell on eBay.
So far, that is 3, 4, 5, 6, 9, 12 seen recently.
Guess I need to keep digging!
I wonder if the 9 was actually a 6 viewed upside down?
« Reply #21 on: January 27, 2017, 02:50:15 PM »
I have several 660s, but not sure if any are the ones you need.
You certainly have a large collection of then!
« Reply #22 on: January 27, 2017, 07:36:40 PM »
So, perfect handle is a style of wooden handle treatment.
Are Smith's the only 'true' PH?
or are other brand  tools with the same style handle in the Perfect society?
Do I really need to be saving all these Coe's with that handle style?
Skip
« Reply #23 on: January 27, 2017, 08:07:07 PM »
Skip, the answer is yes. Smith tools are generally marked "Perfect Handle" on them somewhere. The other tools with wood scales are usually  called a knife handle or perfect handle style.
Whether you save your Coes wrenches or not is up to you. I probably wouldn't keep the common ones, but 6 in., and 18 in. and 21 in. are not as frequently found, especially the two larger sizes.
Keep your eye out for the Smith Perfect Handle 24 in. pipe wrench. These are rather rare, I have had exactly one.
Offline Yodaslo
« Reply #24 on: February 27, 2017, 05:03:47 PM »
"I wonder if the 9 was actually a 6 viewed upside down?"
For reference and clarification for HD Smith #609 screwdrivers, the numbers stamped into the screwdriver tip are viewed correctly when the wooden handle is pointed down and the tip of the screwdriver is pointed up and indicates the straight (untapered) shaft length from the point where the smaller taper on the shaft ends (where the shaft taper starts to widen to fit the handle) and the very tip (working end) of the screwdriver (the side where the stamped number is)
So a number "6" #609 regular screwdriver would have an overall length of the entire tool of 11 5/8", but only a 6" Untapered shaft part.
 (I assume this was to help people [like cabinet makers] determine how far into a hole the screwdriver would work in?)
Yeah. Yeah. Haha much less confusion that way  :shocked:
Hope this helps a very confusing area for us all  :grin:
« Reply #25 on: February 27, 2017, 05:55:14 PM »
I guess that makes sense, but I know that modern screwdrivers are identified by the tip size.
« Reply #26 on: March 04, 2017, 12:53:25 PM »
I just got a #3 off Ebay for $5.99, but was not happy with the $6.99 shipping and handling. I also bought the pliers with the strange logo from the same seller and asked about combined shipping and got no response. He then shipped them together in a First Class envelope!
I know he only paid about $4 to mail the envelope.
« Reply #27 on: March 04, 2017, 01:37:08 PM »
My six-sixty is a winged type #5.
Are all H. D. Smith tools of that type considered to be Perfect Handles?
« Reply #28 on: March 04, 2017, 07:28:01 PM »
Yep.
Offline Yodaslo
« Reply #29 on: March 16, 2017, 03:07:54 PM »
Good point.
I've done a lot of research with the HD Smith Co, and during the researching, I crossed some information that dealt with the sizing issues not being consistent between different nut and bolt makers from this time period. So a bolt from one maker would not necessarily fit the nut from another maker. HD Smith & Co was part of the group who set about "standardizing" these things (HD Smith was partnered for a time with Clark Brothers Bolt Co if I remember correctly).
At the time, (as seen on HD Smith Open ended wrenches icon), HD Smith & Co "tool sizing" method was certainly different than today's standards. For instance, your papa's HD Smith wrench icon has a stamped number on it. The number might be 3/4 let's say. For the HD Smith Co, this indicated the 'Bolt' size the wrench was for (not the 'Nut' size the wrench fit on). So although the actual opening of the wrench measured 1-1/4", the wrench is stamped 3/4.
I haven't located yet the actual "Why" the HD Smith company marked their wrenches this way, but I did locate several nut and bolt company's size charts from that time frame (it was part of the paperwork submitted for the standardization group trying to come up with a method for US universal size standards for hardware nuts and bolts), which listed their own individual companies nut and bolt sizes, which do vary greatly among the various companies.
Knowing that, I guess at the time those screwdrivers were made, standardization hadn't set in yet.  For all of the HD Smith 609 and 660 screwdriver series, there were only 3 shaft diameters used (1/4", 5/16", 3/8"), so the actual screwdriver tips (widths) were limited in how narrow or wide the tip could be once the shaft was stamped with the drop hammers forming the tips. This is the only way, in my mind at least, that I can see for using the shaft length as a size, and by doing so would allow them to sell more than just 3 sizes of screwdrivers.
Anybody here have any reference material on the sizing practices of the time period? I would love to learn more about it.
