Author Topic: Need help with a couple of wrenches  (Read 2665 times)
Offline radguy
« on: August 26, 2011, 01:58:13 PM »
One wrench is marked 0 6164 DB53 and the other is stamped H.N.
Here are a few wrenches with markings 1st on has R1 inside a circle stamped on the end and is 1 x 1 1/8 (top wrench). The 2nd wrench has the number 379 on the center of the front and 9/16 & 1/2 on the ends (the nut sizes are much larger than marked). The 3rd wrench is marked with the number 6491. The 4th wrench has just the letter S on it. The 5th wrench is marked MFD USA and is 9/16 x 1/2.
Dan
« Last Edit: August 26, 2011, 02:03:58 PM by radguy »
Offline Neals
  • Alberta, Canada
Re: Need help with a couple of wrenches
« Reply #1 on: August 26, 2011, 02:16:31 PM »
The second wrench down in the last photo may be IHC. Rathbone lists a 379 and the picture looks right except there are markings both to the right and left of the 379. I can't see the detail to tell what they are. The mark to the right is round so probably IHC.
« Reply #2 on: August 26, 2011, 03:24:45 PM »
 Second wrench should be IHC. Irps lists 4 variations of that wrench and they don't all fit same size nuts.
« Reply #3 on: August 26, 2011, 04:48:55 PM »
>0 6164 DB53
I believe that is a dodge wrench
Rhode Island Tool Co
Funny, it doesn't look like an S wrench...(ducking).
Probably for 'Special' , eg, a non standard size pair for someone
>MFD USA
The panel design is the thing on that one, but I forget whose it is...(indestro????)
Offline BRwrench
  • Ohio
« Reply #4 on: August 26, 2011, 07:23:58 PM »
0 6164 DB53
I belive that the 0 in front is really a Q,  and the DB is for Dodge Brothers.
