Author Topic: Pliers query, what's it?  (Read 3385 times)
Offline SteveSmit
« on: August 22, 2011, 09:57:09 AM »
Hi, I've found this pair of old pliers, and I could do with seeing if I could find another pair. Only problem is I'm not entirely sure if it's a specific type of pliers that you can buy from somewhere, or it's something that was made many years ago as a one off. It appears as though it's been heat treated, though, and looks to be a straight up tool.
I've done a little drawing of it, how it looks with the jaws fully closed so you get the idea.
Hopefully someone can point me in the right direction!
Thanks in advance.
« Last Edit: August 22, 2011, 10:21:09 AM by SteveSmit »
Offline m_fumich
Re: Pliers query, what's it?
« Reply #1 on: August 22, 2011, 11:52:32 AM »
Need to know what the jaw is like. Is there a cutting edge at all? What's the shape from above? Is the inside of the jaw rough for gripping?
Offline SteveSmit
« Reply #2 on: August 22, 2011, 12:03:33 PM »
Above it's just a plain shape The shape of the jaws shown in the first drawing is the same across the jaw's width. There's no sharp cutting edge. When closed the jaws don't meet at the tip.
Offline m_fumich
« Reply #3 on: August 22, 2011, 01:26:19 PM »
Almost sounds like hog ring pliers. They're made to pinch something closed to that specific spacing. Hog ring pliers have a grove for the rings to nest in.
« Reply #4 on: August 22, 2011, 02:29:58 PM »
Could be grousing pliers also....
Offline ToolsorDie
« Reply #5 on: September 03, 2011, 06:50:42 PM »
Post actual pictures when you can.
